by ciamcoop » Fri Mar 16, 2012 3:37 pm
I just rebuilt mine 2 months ago and have about 4500 miles on it. I drove from Oregon to Colorado and got 21.9 on the first tank and 22.6 on the second tank. I hit 75 MPH a few times but mostly kept it at 70. Before the rebuild I would get 18 to maybe 19, I think the cam and lower compression helps a lot, also I didn't advance the timing much and I think that helps with lower rpm and light load performance. I run Valvoline blue oil, not synthetic) and usually add Lucas to the fuel. I drive fairly conservative, but am not afraid to get on it if I have to. I do try to keep boost below 20 psi and egt under 900. I don't lug it either, if going less than 60 up a steep grade I'll pull it in 4th, egt and boost both drop, which means I'm using less fuel.
'93 W250LE 4x4 club cab, getrag, denny t, 366 spring, 181/210 cam, bored. 020, KDP, 5x.014's, piston pump, 4" tbe, cold air, 255/85/16s, 3.54's one wheeler peeler
