Water to Air Aftercooler Intakes bought new?
Postby TheTowingCowboy » Mon May 07, 2012 7:01 pm
Title says it all any place I can buy one new... and not have to trade in my first born child? And anyone have a clue where I could get unbent fuel lines so I can just bend them my self.
Thanks guys!
TheTowingCowboy
Re: Water to Air Aftercooler Intakes bought new?
Postby ahale2772 » Tue May 08, 2012 4:52 pm
sheid, industrial, keating can all get you unbent lines, just specify VE ends and they can get whatever size you want.
ive got a set waiting to be bent up from sheid, cost me just over 300$
best place to ask about the inter/middle/after cooler is cummins
Postby TheTowingCowboy » Tue May 08, 2012 7:27 pm
GOt a parts number I can use? Lol
TheTowingCowboy
Postby ahale2772 » Wed May 09, 2012 6:29 am
just call them up, mine are plain steel, .93, and the longest length they sell, I will see if they gave me a part number but IDK if i even have the slip anymore, got them from sheid
Postby PToombs » Wed May 09, 2012 5:33 pm
Why not just buy the factory tubes?
Postby ahale2772 » Wed May 09, 2012 6:17 pm
they probably cound not figure out what he meant when he said he wanted the prebent lines for a middlecooler :)
Postby PToombs » Thu May 10, 2012 5:27 pm
Ok, but that's an aftercooler, a middlecooler is the one in front of the radiator. Man it's hard to start a new trend when you guys don't GET it! :roll:
Lines aren't a big deal, go the Case dealer and tell them you need the lines for a 2144 Axial-flow combine with a serial number prior to JJC0173150. Or if you ask nice I could give them to you as I have the parts breakdown in my hand. :mrgreen:
Only thing is, that 'cooler ( ;) )looks way bigger than normal, so I have a doubt that the lines are correct with out comparing measurments.
Postby TheTowingCowboy » Mon May 14, 2012 7:30 am
No I meant parts number for the aftercooler. I can bend my own fuel lines
TheTowingCowboy
Postby bgilbert » Mon May 14, 2012 8:17 am
Aftercooler 3919806
Injection line #1 3926389
" " #2 3926390
" " #3 3926391
" " #4 3926392
" " #5 3926393
" " #6 3926394
ESN for aftercooled VE pumped engine c/o Greenleaf is 44342895.
For Case/IH ordering - about half of what Cummins wants, replace the first '3' in the part number with a ' J '.
Bill Gilbert
bgilbert
Postby TheTowingCowboy » Mon May 14, 2012 9:35 am
bgilbert wrote:Aftercooler 3919806
" " #2 3926390
" " #3 3926391
" " #4 3926392
" " #5 3926393
" " #6 3926394
Can I buy you lunch???
TheTowingCowboy
Postby SWI Don » Tue Dec 23, 2014 10:48 pm
How tall is the aftercooler above the inlet flange of the head? Does the heating grid add to that?
Trying to see if it will fit under the hood of my truck.
Thanks,
Don
1994 Chevy K2500 w/ 93 NON-I/C 6BT-A, 60# valve springs, H1C w/16cm housing, NV4500, 4:10 gears. My beast of burden.
SWI Don
Postby Tacoclaw » Wed Dec 24, 2014 3:30 am
Your grid heater won't work with the factory aftercooler. I'm heading to work but if nobody's answered I'll measure mine when I get home.
Postby SWI Don » Wed Dec 24, 2014 6:41 am
I've seen pictures of a different grid heater for the aftercooled engines. It was long and skinny to match the shape of the bottom of the aftercooler. Part nos for the grid heater spacer are 3928464 and the heater itself 3928465. Found them here:
http://www.cumminsforum.com/forum/cummi ... ooler.html
SWI Don
Postby SWI Don » Sun Jan 04, 2015 8:04 pm
Tacoclaw,
Did you get a chance to measure the height of your aftercooler?
Thanks,
Don
SWI Don
Postby KTA » Mon Jan 05, 2015 6:52 am
The factory water to air aftercooler clears fine on old yeallow. I have a grid heater for an aftercooler and it will not clear the hood insulation with it, you would need a 2in body lift to get it to fit.
