by motorwood » Mon Jul 02, 2012 1:52 pm
Ive been running a 14mm over a year now. I have a boost regulated dual fed fuel system (a1000 with 5/8ths line) never see the case pressure drop others post about. Once the check valve opens (about 100psi) on my return feed line my pressure holds and then climbs close to 150psi with boost and rpm. 14mm h/r's are supposed to be hard to keep fueled, mines not. Also haven't been able to get over 455 HP. I'm turned up just shy of runaway. Egt's max around 1700*. I appreciate some ideas from those who are making big power. Is the secret in the fulcrum lever?
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857
13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
