by bmoeller » Fri Aug 17, 2012 7:28 am
m880cummins wrote:
Would marine pistons be a good option for a P pump engine with twins?
Only if you intend on running marine fuel injection nozzles. Spray angle is different between the truck and marine. You can run marine nozzles in a truck, but you need to use the thinnest washers you can get, to get the tip in far enough that fuel won't spray outside of the piston bowl.
m880cummins wrote:P pump kinda scares me
![Gear Roll :;-|:](./images/smilies/gear_roll.gif)
I think I will send it out!
You need to anyhow. Needs to be put on a test stand to get everything balanced (even flow of cc's across all 6). A clean room is the best place to work on one as it is.
Will you get the P-pump maxed out? If not, the HX40/HT3B combo might be overkill. HX35/HT3B might be a better choice.
NEW- '82 CREW cab dually. Cummins, NV5600, 205, D60/D80.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Work in progress......
SOLD- '99 3500, SO CTD, 5spd
