blackvmax07 wrote:I just want to pull about 5000 pds and blow some smoke in the process, thanks for any help.
oldestof11 wrote:Welcomeblackvmax07 wrote:I just want to pull about 5000 pds and blow some smoke in the process, thanks for any help.
So many things I want to say...
RCCUMMINS89 wrote:Personally I think the best set up for a good driving, very strong towing, fun daily driver is:
hx35 (basicaly a direct bolt up), or s300 ($1000 or more)
4" exhaust
fuel pin (stg 1 or ground stock pin)
Big air filter
Pump tuning to your likes.
The above will make it drive like a beefed up (mildly) p pump.
RCCUMMINS89 wrote:na... you won't need to do injectors unless you want to run a turbo larger than a 60mm
blackvmax07 wrote:ok cool, is it ok to buy a used turbo and wat do i look for if its used?
