14mm ve
14mm ve
Postby cummins12club » Sat Sep 08, 2012 5:35 am
I am planning on installing a 14mm rotor head on my 93 and was wanting some feedback from u guys that have already done this. What is your opinions of the 14mm and what special things should I know/change to accommodate the use of the 14mm also install tricks and need to knows would be nice too, thanks
cummins12club
Re: 14mm ve
Postby Tacoclaw » Sat Sep 08, 2012 7:10 am
What are the current mods and planned usage for the truck?
Re: 14mm ve
Postby JQmile » Sat Sep 08, 2012 8:21 am
Loctite the front seal and run at least 15psi at idle and 30+ under boost. I run an AirDog II at 35psi all the time. I also wouldn't put anything crazier than a 3200 spring in, 14mm pumps don't like rpm. Use big injectors, 6x16 or 5x18, and run lots of timing....close to 30 degrees if you're on fuel. They seem to live alright, as long as you don't rpm 'em, or starve them for fuel.
JQmile
Re: 14mm ve
Postby cummins12club » Sat Sep 08, 2012 11:01 am
I currently run a 4k spring although I never spin it past 3200 theirs no point it defules as far as supporting mods I will be running an hx35 over an ht3b and have read that 5x18 injectors are a must to keep the 14 alive I was looking into Rocken tech products 14mm head and they claim u can spin it to whatever rpm u want as long as u have the fuel to do so I deffidently need to pull the pump off to do this right? And also would ..93 lines be neccasary/benifitcial? This is a street driven truck that will be at the drag strip very frequently and if im feeling frogy and wanna hook to a sled I'd like to be able to
cummins12club
Re: 14mm ve
Postby JQmile » Sat Sep 08, 2012 8:04 pm
Yup, you need to the pull the pump. Actually, you should probably have a shop install it, if you have the dough, just don't let em run it on a test stand, most shops use itty bitty injectors which can kill it. I wouldn't buy the rpm thing, I know people who have killed 12mm pumps by trying to make power over 4K. I'd also skip on the lines until you do everything else.
JQmile
Re: 14mm ve
Postby cummins12club » Sun Sep 09, 2012 7:55 am
I'm the kind of person who likes to do things myself I have a spare ve pump laying around and theirs a guy on the Internet w an extensive how to video book and pictures on rebuilding the ve yourself but if I were to take it to a shop how much cash are we talking? I never plan on spinning it up to much less past 4k bc847 shifts his 12mm at 3200 and runs 13.flat in the quarter to clearly rpm is not the ticket to big power I've just heard bad rumors about the 14mm rotor head kills the ve life u said before a good lift pump system is needed too. Correct?
cummins12club
Re: 14mm ve
Postby JQmile » Sun Sep 09, 2012 8:39 am
Most of the 14mm VE deaths can be attributed to either too little lift pump pressure, too much rpm, too small of an injector, or a combo of all three. I'd recommend an Air Dog 165 at least. A few years ago a lot of sled pullers were trying 14mm VE's, and trying to leave the line at 4K-4500rpm. That didn't work, but you can't blame em for trying. I know a lot of street trucks on here (KTA, BGilbert, Jayers, STOMP, and me) who have been running 14mm pumps for years reliabily.
JQmile
Re: 14mm ve
Postby cummins12club » Sun Sep 09, 2012 7:45 pm
Yea I'm an avid diesel bomber reader and have been following project rust bucket what's ur opinion on 5x18 injectors?
cummins12club
Re: 14mm ve
Postby JQmile » Sun Sep 09, 2012 10:01 pm
I don't know anyone who has run 5x18s, but I don't see why they wouldn't work well. I make just as much on fuel with my 5x25s as I did with 6x16s, if not more.
JQmile
Re: 14mm ve
Postby cummins12club » Mon Sep 10, 2012 4:14 am
I wanna run 5x18s cause I feel like 5x20s aren't Gunna make more power and I'm planing on runing an hx35 for my top turbo I'm afraid I'm going to smoke out the top turbo w even 5x18s
cummins12club
Re: 14mm ve
Postby jkidd » Wed Oct 10, 2012 7:14 am
Where is the best place to buy a 14mm head/rotor. Also saw there was a 4mm cam plate available. Any thoughts on it?
jkidd
Re: 14mm ve
Postby RCCUMMINS89 » Wed Oct 10, 2012 7:21 am
The ONLY place that I know of is Rocken Tech, for both..... I'm under the impression...ok well I know, that CPP is getting theirs from Rocken Tech. Also I'm not sure if anyone has EVER made the 4mm camplate work and not seize the pump.
Re: 14mm ve
Postby Farmboy92_2009 » Sat Oct 13, 2012 10:48 pm
I called rocken tech bout 2 weeks back and if I remember right it was $408.50 I think for the 14 mm head/rotor...
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
