raptor 150 not wanting to turn on
Postby 91bluecummins » Wed Sep 12, 2012 8:46 am
in my 1991.5 i put pod injectors in it and the next day the pump quit working. you can tap on it and it it will turn but it doesn't sound like its turning as fast as before. the fuel pressure gauge will stay at 11psi and then drop to 0. but the truck still runs fine. do yall think the motor is going out.thanks
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: raptor 150 not wanting to turn on
Postby Hansen01 » Wed Sep 12, 2012 12:54 pm
Check your connections and if there all tight then yea, its prolly goin out, How old is your pump?
Under construction...
Hansen01
Postby dazedandconfused » Wed Sep 12, 2012 1:28 pm
Sounds like the motor on the pump is shot.
Postby 91bluecummins » Mon Sep 17, 2012 2:58 pm
well i took it off and the pump was burned up it smelled like a real big eletrical fire =(
i called airdog and there gonna send me a new pump glade i turned in the warranty card
91bluecummins
