isspro Tach
isspro Tach
Postby directinjktn1stgen » Mon Sep 24, 2012 6:37 pm
anybody running this ISSPRO R5503 on 92-93 ram trucks on genos garage it says the gauge only for sale then a required wiring harness thats 30 bucks extra is there anything special thats not pictured that u need for the setup cause if not i can make that myself without paying 30 bucks if anybody know please let me know thanks
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Re: isspro Tach
Postby CumminsPower59 » Mon Sep 24, 2012 7:19 pm
I am running that tachometer, I made my own wiring harness. It takes a little bit of patience and finness to get the fabbed leads into the oe socket, but it works. A quick search on here will net you a diagram on how to make one ;)
Re: isspro Tach
Postby directinjktn1stgen » Tue Sep 25, 2012 2:45 pm
i figured there proabably was thanks for the help
Jeffery
directinjktn1stgen
Re: isspro Tach
Postby BC847 » Tue Sep 25, 2012 7:12 pm
http://www.dieseltruckresource.com/dev/ ... p?t=173561
Do not buy the ISSPRO adapter. It's not needed in our application. Just get some 22awg and run the tach reference line directly to the trucks tach signal line found under the dash.
Re: isspro Tach
Postby directinjktn1stgen » Wed Sep 26, 2012 4:49 pm
ok thats what i was figuring when i seen the harness they had for sale i was like i can make that
Jeffery
directinjktn1stgen
Re: isspro Tach
Postby Billy Bones » Sat Oct 20, 2012 2:29 pm
So what does someone like me do that doesn't have a dash just the Cummins is there a wire coming from the motor?
Billy Bones
Re: isspro Tach
Postby peobryant » Sun Oct 21, 2012 1:37 pm
Billy Bones wrote:So what does someone like me do that doesn't have a dash just the Cummins is there a wire coming from the motor?
Isspro makes kits for trucks without the wiring, and I believe it comes with magnets you stick to the harmonic balancer or alternator. What year is the engine?
Re: isspro Tach
Postby Billy Bones » Mon Oct 29, 2012 9:31 pm
I got the moter out of a 85 F350 It's supposed to be a 92. The guy I bought it from said it had a stock tach too but he pulled it off it was mounted on the front of the timing cover where most motors have the oil fill mines just plugged now.
Billy Bones
