soggy wrote:I don't know about the 4mm, but do you have part numbers for the solid rollers and high rpm springs?
Plunger return spring kit 1-467-010-410.
Solid cam roller kit 1-467-010-535.
I've got a few different VE pumps laying around. So far I've found two different camplate part numbers, a stock 114 nonIC pump stamped 440 (also found in a nonAFC industrial pump), and one from a 93 205 pump, which happened to also be found in another industrial pump I had laying around. IIRC it said 8995, I'll double check. My HF dial caliper says the 205's pump has a slightly larger lobe... Where is the 3.2 camplate found?
