Which 2 and 1/2 turbo?
Postby motorwood » Mon Oct 01, 2012 12:23 pm
I'm putting together a 2 and 1/2" inlet turbo for a street pulling class. Would I be better of going with a turbo with that sized inlet or using a larger charger with a clipped wheel and a custom cover? I have plenty of fuel up to 3000rpm.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Re: Which 2 and 1/2 turbo?
Postby dazedandconfused » Mon Oct 01, 2012 2:42 pm
Try a modded S471 or 475. That seems to be what the 2.6 guys start with around here
Postby motorwood » Mon Oct 01, 2012 5:36 pm
I have a choice of pitting a 362 wheel and cover on my 366, clipping an hx60,clipping a 4202, clipping a 468, or clipping an hx52.
motorwood
Postby Farmboy92_2009 » Mon Oct 01, 2012 5:54 pm
gt4202 is where its at.
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
