cmann250 wrote:Is your truck factory intercooled?
RCCUMMINS89 wrote:Yes, you are pushing too much boost for stock head bolts.
The 3200 gov should give you a higher boost number. Becuase you are more available fuel at a higher rpm equals more exhaust velocity through the turbo.
A timing jump however will decrease your boost a little, even though an 1/8th might not be enough to change it. Reason is you are holding more heat in the cylinders which doesn't spool the turbo as much.
Tacoclaw wrote:Horsepower estimate would be around 230-250 if it's an auto. A bit higher if it's a stick, but I'm assuming it's not since you're rebuilding it. Your torque number will be higher with an auto, but my dyno run didn't read it anyways so it won't be a worry to you if you can't see it.
There's also a chance you'll end up on one of those dynos that will give you a 300+ number, but I wouldn't put too much heart into it. My truck, with a stick and an S362 did 268 horse. Stock injectors, fuel pin, LPLP, and 4" exhaust.
Do you have an upgraded LP?
