Bluebird injectors
Bluebird injectors
Postby Ram360man » Sat Oct 20, 2012 11:00 pm
Picked up a bus for really cheap. Wondering if they just run the standard non I/C 9mm injector or something else. It's a 89 model with the after cooler.
1989 W250. Maxed fuel pump. 5x14. 63/68/14. PS Intercooler. 4200 gov spring. 188/220 cam. Built 727
1989 W250 60mm gds. 2.5 inch crossover. turned up pump. Stock 727.
Ram360man
Re: Bluebird injectors
Postby bgilbert » Sun Oct 21, 2012 6:09 am
If the head hasn't been replaced for a 7mm head sometime in it's life, it will have a 9mm injector, but a 5 hole version vs. the Dodge 4 hole. Seemed to make the same HP the nonic 4 hole did (which is respectable compared to IC'd injectors). Oldcool90 ran them for awhile.
Bill Gilbert
bgilbert
