using a hobbs pressure switch to turn on secound fuel pump?
Postby 78fordf150ranger » Tue Dec 04, 2012 10:26 am
Got thinking at work today, If.I was to get a electric fuel pump and keep the stock lp but had a Hobbs switch hooked up so under hard acceleration it would kick the electric fuel pump on and once the boost gose back down the electric pump would shut down so I wouldn't have to high of fuel pressure and blow the seals out of the injector pump.
Would this work.
78fordf150ranger
Re: using a hobbs pressure switch to turn on secound fuel pump?
Postby DodgeFreak » Tue Dec 04, 2012 10:56 am
Why not run hplp with a boost reference regulator?
