the 5x20's were almost exactly the same size as the 6x18's
(1570 vs 1526)
did you notice any difference between the two?
LOL, on the same dyno Josh did not match my lowly hp number. You can't compare numbers from different dyno's, you should know this by now mr. arm chair diesel guru . Plus my little 443hp number was with no intercooler. I've discovered my 3gal a minute water pump wasn't working enough, let alone big enough to start with, to circulate the ice water.DTanklage wrote:josh used 6x18's to match billy bobs numbers and he is only using a 62mm wheel compared to bobs 71!
TWorline wrote:
I think Bill handled that rather well
