Tacoclaw wrote:Any chance the lift pump crapped out on you?
142autox wrote:Was running 30ish now 22ish. I've backed the fuel screw out several turns from where it was originally and still too much smoke and not enough go. The star wheel is up 4 full turns and smoke screw is flush with the top of the housing. The wear marks on the pin show a full sweep of the ramp.
RCCUMMINS89 wrote:142autox wrote:Was running 30ish now 22ish. I've backed the fuel screw out several turns from where it was originally and still too much smoke and not enough go. The star wheel is up 4 full turns and smoke screw is flush with the top of the housing. The wear marks on the pin show a full sweep of the ramp.
This tells me boost leak...or timing.... 22# of boost and blowing black, that's the issue that needs to be looked at.
