VE Springs 3200, 3800, 4200??
Postby jmos4 » Thu Dec 19, 2013 10:50 am
Hi,
Been doing a little research and wondered, why do most use the 3200 spring and why not use the ones with a higher rpm, I realize most of the power these engines make are in the 1700 range but the rpm might come in handy going down the freeway.
is there a drawback to the higher springs?
Regards,
Jim
1992 Dodge 250 4 x 4
currently 360 TBI
NV4500, NP241
Dana 60's 4.10 gears
soon to be Cummins powered
1989 D250
Cummins NV4500 (Donor)
jmos4
Re: VE Springs 3200, 3800, 4200??
Postby RCCUMMINS89 » Thu Dec 19, 2013 11:31 am
Not much advantage going over 3200.
Advantages to over 3200 - more responsive throttle in the upper rpms, drag racing... it can come in handy (can).
Disadvantages to over 3200 - throttle can be so touchy it makes it hard to drive at low speeds (surges, hard to keep pedal steady enough).
Postby DodgeFreak » Thu Dec 19, 2013 12:37 pm
I believe I'm running an Unclipped 3800 spring in one of my piles. It doesn't fuel any different than my 3200 in my crew cab that I can tell. If I clipped it, it might change it. My plan is to clip the 3800 and try it. The pump is maxed and has a dennyt stage 2 pin.
Postby RCCUMMINS89 » Thu Dec 19, 2013 12:46 pm
All I noticed is a more responsive throttle.
Postby DMan1198 » Thu Dec 19, 2013 3:40 pm
Don't forget over 3200 and heavier valve springs are recommended to negate the possibility of valve float
Postby RCCUMMINS89 » Thu Dec 19, 2013 3:43 pm
Yep....good point.
That is also possibly the reason that I don't have a gain. I am not experiencing bad valve float...but who is to say they are not open just enough to mess up power. Not to mention that at around 50 psi intake valves get blown open...which I'm also over. All with stock valve springs.
