Need 12mm pump for race520 nozzles and high rev engine
Postby zeejay83 » Sun Dec 22, 2013 2:50 pm
Hello i buy pump from lt 12mm i want to put that rotorhead to 10mm pump.
What i read good high rev springs is 1 467 010 410 but what about springs from engine called 1z from vw. Someone said those springs are better but why. Anybody know?
I also need part number for new rotor head replace for tdi pump. Merry X-mas guys...
zeejay83
Re: Need 12mm pump for race520 nozzles and high rev engine
Postby BC847 » Tue Dec 24, 2013 12:04 pm
Hey ZJ, WELCOME to our forum. 8)
I'd be interested in the same info. I can't say however, that we get much chatter about the VW (4cyl) pumps.
It would be neat if we could come up with a list of parts from the higher RPM capable 4-cylinder VEs, that could be interchanged with the 6-cylinder pumps (for the purpose of higher performance).
Postby RCCUMMINS89 » Tue Dec 24, 2013 5:27 pm
if/when I can remember..... I can get part numbers for the "new high speed" camplate rollers (ceramic coated or something of the likes) and the high speed return spring p/n.
Postby littleboy » Wed Dec 25, 2013 3:19 pm
Just curious, how many rpms are you wanting to run ?
96 converted to ve pump because p-pumps are overrated, always testing/playing with parts to get it running better.
littleboy
Postby zeejay83 » Fri Jan 24, 2014 12:06 am
I think about rpms to 5000rpm on 12mm pump.
I have numbers for standard rollers 1 467 010 535
original 12mm sprongs 1 467 010 495 the same like 10mm pump( i think somebody use them for high rpms )
12mm rotorhead like mine is 1 468 334 870.
So that long springs are used in perkins engin rev to somethng about 4500. So not bad and i think that engine have smaller nozzles than mine 0.260. I read that short aprings are not best for 12mm , make less power over 4000rpm.
And i need number of that
zeejay83
Postby bgilbert » Sat Jan 25, 2014 7:05 pm
zeejay83 wrote:I think about rpms to 5000rpm on 12mm pump.
The part number you list for standard cam rollers do not look like the two piece rollers you have pictured. They are for 'solid' one piece rollers. Unknown what application they are from, but they are what I use when I build a pump. The plunger return springs I use are what you listed in your first post. They are known as 'high rpm' springs. Again, they are unknown application. They are also the same length as Dodge springs.
Bill Gilbert
bgilbert
Postby zeejay83 » Thu Jan 30, 2014 3:39 pm
So nobody knows number of 2 piece rollers on photo?
zeejay83
Postby bgilbert » Thu Jan 30, 2014 5:50 pm
zeejay83 wrote:So nobody knows number of 2 piece rollers on photo?
Why use standard stock pieces and not the high rpm solid rollers? Is this a stock restoration? :lol:
bgilbert
Postby cubedeficient64 » Sat Feb 01, 2014 9:26 pm
I have a pump with the double rollers. 0 460 426 088. I have no Idea what or where to find the roller part numbers.
Pump numbers 0 460 426 218 / 219 are for 3900rpm applications, might be worth looking into what rollers they use.
cubedeficient64
Postby zeejay83 » Sun Feb 02, 2014 5:29 am
So 1 467 010 535 cam rollers is the best option for hghm rpm?
zeejay83
Postby bgilbert » Sun Feb 02, 2014 8:01 am
zeejay83 wrote:So 1 467 010 535 cam rollers is the best option for hghm rpm?
Yes.
bgilbert
Postby RCCUMMINS89 » Sun Feb 02, 2014 8:06 am
Bill.......I was told that there are "high speed, ceramic coated rollers". Are those it? Or was my shop guy telling me about something new?
Postby bgilbert » Sun Feb 02, 2014 8:56 am
RCCUMMINS89 wrote:Bill.......I was told that there are "high speed, ceramic coated rollers". Are those it? Or was my shop guy telling me about something new?
I can't say. These look to be the same material as the two piece rollers. Everything is top secret to pump shops unfortunately, so getting the part number from him is probly not gonna happen?? FWIW, the plunger springs and cam rollers I use, Scheid uses them for all their pumps.
bgilbert
Postby RCCUMMINS89 » Sun Feb 02, 2014 9:07 am
If I called him back up, I could probably get the p/n he is claiming. It is just remembering during the week.
Postby zeejay83 » Wed Jul 09, 2014 5:42 am
I finally use that 12mm rotorhead and problem is with high rpm. On 5th gear there are no power over 4200. It look like less fuel in rotorhead or springs must be more harder. What do you think where is the problem. There are people woho rev 12mm pump to 5500+ and power do not go down.
zeejay83
