Homebrew HE341/HX55 compounds
Postby sundaybacon » Wed Feb 19, 2014 10:41 am
'll start with a little background on the truck. Bought it in Dec 2011. 2 1/2 owners 197k.
Not long after, I cranked the pump, fuel pin, lift pump, 3800 gov spring. Valair kevlar ceramic, he341, 4" TBE, PS intercooler, 3" charge pipes, 6" all spring lift and 38" boggers.
Then added DFI 5x14s , JGS 60mm BOV and a 351VGT with a 5" hood stack
VGT was a pain in the butt . Back to he341 with spring gate and 5" TBE
Found a deal on some 38x9 michelin zxls
sundaybacon
Re: Homebrew HE341/HX55 compounds
Postby sundaybacon » Wed Feb 19, 2014 10:44 am
Now to the good stuff.
He341 over hx 55
In the truck.
And the POS I tow behind the Dodge. Just finished the turbo propane set up
Head is off for ARPs and O rings since I popped the gasket a few weeks ago. So when its back together, Ill get to drive the twins.
sundaybacon
Postby RCCUMMINS89 » Wed Feb 19, 2014 10:52 am
NICE....
Oh and I really like the way you did your twin setup...
Postby DMan1198 » Wed Feb 19, 2014 10:53 am
Nice setup. Are you using any bracing on the primary?
Postby sundaybacon » Wed Feb 19, 2014 11:53 am
Thanks guys. I knew looking at otherr setups online prior to the build, I had to have a side by side set up. No fun when you hide the primary under a bunch of pipes.
Definitely going to build a brace off the motor mount to attach to the hot pipe.
That 55 is a heavy pig.
Charger specs if anyone is wondering. Might be a hair off from my crappy memory so dont sue me haha.
341- 54/58/9
55- 66/77/22
Still need to...
-skip a tooth on the timing gear
-Hot pipe brace
-fab dual ram intake/turbo-ic charge pipe
-Full 5" downpipe
-Port exhaust manifold
-Port 341 wastegate
-Run new lines for JGS blow off valve. This thing has been a huge b*tch to dial in, despite all claims online(go figure). But Im determined to figure it out and not give up on my $300 lemon haha.
2014 has not been a good year so far. Popped the cummins and Toyota HG in January, so now I have 2 motors ripped apart on my kitchen table, I'll try and snag a pic.
sundaybacon
Postby cmann250 » Wed Feb 19, 2014 7:01 pm
I almost don't recognize you over here without the avatar :lol:
Postby jmiko » Sat Feb 22, 2014 4:22 pm
Hey! First off that looks awesome! and secondly your thread has given me the inspiration to finish my long lost hx35/55 twin build! I have a few questions to ask about yours if you don't mind.
1. What tuning problems have you ran into? Have any boost, pyro or drive pressure #'s?
2. 3" cold/hot piping correct? What types of steel for each? and did you just weld the foot for your 55 straight to the hot pipe?
3. What did you do about oil lines/fittings?
4. How are those DFI's treating you? I got some 5x14sac from them last year, never been happier with an injector!!
Thanks in advance sorry for all the questions, days off are short and i want to get this done before summer haha, possibly have anymore pics?
jmiko
Postby sundaybacon » Sat Feb 22, 2014 8:55 pm
cmann250-Thanks for the reminder, maybe Ill get another lecture on how a nice ass isn't the only female attribute that matters haha :roll:
Thank you sir, those are all the pics I have. No prob with questions, I just like seeing people interested in my build!
I built the setup right after I parked my truck to pull the head. Gasket popped a week prior, so its torn down getting ARPs and Orings, havent drove with the twins yet. But Im guessing with the fuel I have, it should put me around 50-60psi, spool super fast, and cool decently with some tuning. Built a spring gate for the 341 awhile back and its stupid easy to adjust.
I love the DFIs! I was kinda leery since I bought them off ebay, but for the set up I was running (overfueled-small 54mm turbo) a little AFC tuning went a long way. Didnt have to worry about eclipsing the sun from every stop light. Only a slight warm up haze. Twins should only make them better.
As far as oil lines, dont have the primary drain done yet, but already have a bung welding in the pan. Im just using 7/8 silicone oil rated hose, hate the place but source auto sells it by the foot.
The hot pipe is 3" sch 40 mild steel elbows, bought from Ferguson plumbing, locally. Flange is off ebay. I still need to break the tacks off the flange and make a divider to go in the pipe beforehand to help smooth out the transition.
I may not be a great fabricator, but having a welder pays for itself, thats for sure!
sundaybacon
Postby AHineman » Sat Feb 22, 2014 9:20 pm
Looks awesome!
Makes me want to build a set like that for my '90 model. I'll add that to the list of things that need done to it. (too bad the list is like 6 pages long :lol: )
Postby cmann250 » Sun Feb 23, 2014 6:24 am
sundaybacon wrote:cmann250-Thanks for the reminder, maybe Ill get another lecture on how a nice ass isn't the only female attribute that matters haha :roll:
You won't hear any complaints from me. :lol:
I have a BHT3E floating around that'll end up beside my HX35 one day. My piping will be the same as yours except the primary spins backwards.
sundaybacon wrote:As far as oil lines, dont have the primary drain done yet, but already have a bung welding in the pan. Im just using 7/8 silicone oil rated hose, hate the place but source auto sells it by the foot.
Drain- I'm just going to cut out a ~3/4" flange and tap in a big hose barb.
For what it's worth Keating does not make divider or do any sort of blending on their stuff.
AHineman wrote:Looks awesome!
Rest in peace 727 :lol:
Postby jmiko » Mon Feb 24, 2014 7:59 am
Awesome thanks for the info! Helps alot, Ive got a steed speed vband manifold and was thinking i could help drive pressure with it and that would relieve my poor hy35 hopefully, oh and the manifold? BEST purchase on the truck (well one of them haha) just letting you know because you want to port yours and to me the Steed Speed mani was worth every penny!
jmiko
Postby sundaybacon » Thu Mar 27, 2014 12:00 pm
New O-Ringed head and ARPs are in. She lives again. Have done one heat cycle and retorque so far, Still have some random stuff to make here and there. Just about to go finish the downpipe then take her for a spin. Here are some pics in the meantime.
Ported vs Stocker
Ready to impale the head on these money stakes.
60# springs and Orings. Nothing special.
Hot pipe wrapped.
Inlet divider fabbed for t4i flange.
Ghetto fabulous hot pipe support made from some bedframe, tied to motor mount, stock holes.
Started polishing comp housings, but didn't finish and It shows. Holding off on this, just want to drive my truck.
Got em back in to start plumbing.
With the 6" AFE on there.
Still have some heat cycles/retorques left. Being super OCD about it. Don't really want to do a HG again for awhile. Then Ill start tuning and get some vids.
sundaybacon
Postby SNOOT » Fri Mar 28, 2014 11:29 am
Sweet!!! I still remember the first day I fired my truck up with twins..
1993 W350
SNOOT
Postby DMan1198 » Fri Mar 28, 2014 11:43 am
It was neat seeing that Instagram video of this thing running
Postby 91bluecummins » Sat Apr 19, 2014 12:19 pm
looks good
man
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
