performance setup
performance setup
Postby 720JohnDeere » Tue Mar 11, 2014 2:50 pm
[size=150]ok heres my situation I have a 93 intercooled motor with an he351cw my pump mods are fuel turned up lots no afc arm and supposibly a set of pods injectors.. I have a set of 5x18s and i was thinking about getting a s366 or a bd super b special its a 5speed truck i would love to see 400hp give me options on how to make it there.. i know 5x18s are over kill but there what i have in stock give me different variations i could use to see 400hp numbers
1993 w350 5speed
720JohnDeere
Re: performance setup
Postby BC847 » Tue Mar 11, 2014 7:10 pm
WELCOME to our forums. 8)
What are you gonna do with the truck?
Postby 720JohnDeere » Tue Mar 11, 2014 7:45 pm
its just a toy
1993 w350 5speed
720JohnDeere
Postby dazedandconfused » Wed Mar 12, 2014 4:00 am
I honestly think it would run better and make more power with a properly tuned AFC functioning. I would think once you put those big injectors in it will be hard to light and keep the turbo lit without having to work at it with the right foot.
Postby 720JohnDeere » Wed Mar 12, 2014 12:26 pm
two of my buddys have there afc deleted and they run a lot better no joke i think what im gonna do is for my turbo set up my he351 over an s475 i want it to light fast plus i need all i can down low were my pumps fueling hard an those twins would clean up my 5x18s.... whats yalls take on that?
1993 w350 5speed
720JohnDeere
Postby AHineman » Wed Mar 12, 2014 2:16 pm
You can get the same amount of overall fuelling and keep your AFC. If you grind your AFC lever/fuel pin(cone) so you get full travel, you make the pin that rides in the cone longer to match. There's a write up on it over on DTR.
Postby 720JohnDeere » Wed Mar 12, 2014 5:51 pm
hell I was given a denny t afc delete cover so I threw that on with the 345 spring
1993 w350 5speed
720JohnDeere
Users browsing this forum: No registered users and 69 guests
