Messin' with the AFC
Postby RCCUMMINS89 » Sat May 31, 2014 3:50 pm
Ok.... so, I decided to mess with the AFC today and cut back zero boost fueling as much as I possibly could.
If one flips over the AFC top and looks at where the afc lever hits the housing itself..... Right there the housing can be ground back at least a 1/4".
IMPORTANT FUTURE NOTE: .157" is the diameter of the stock slide pin..... a 5/32" drill bit is .15625"..... close enough :mrgreen: .
Doing the above, my new slide pin is a full 1/4" longer than the longer slide pin that I sell on the site. Or 1/4" + .5mm longer than stock.
Result.... it helped, but it is still not anywhere near enough for my heap. :roll: :lol:
Re: Messin' with the AFC
Postby Kasper Cummins » Sat May 31, 2014 7:08 pm
What's the purpose of a longer slide pin? Just less over all fuel?
92 W250 club cab
Kasper Cummins
Postby RCCUMMINS89 » Sat May 31, 2014 7:14 pm
Less zero boost fueling. Custom grinding the fuel pin, can still give full fueling. So in short, it allows you more afc control.
Users browsing this forum: No registered users and 71 guests
