ECU FAILED
ECU FAILED
Postby danc » Wed Jul 30, 2014 3:59 pm
MY ecu is not sending votage to the trans and the speedo keeps dropping out. Anyone one know where i can find an ecu for sale or have mine rebuilt. I miss my overdrive. Thanks
1993 club cab 2wd, auto,s300,5x14s,BHAF,powertrax,denny t, Carter 100gph,specrite tc, built 518,tampered pump,and a new headliner.
danc
Re: ECU FAILED
Postby Philip » Sat Aug 09, 2014 5:40 am
The PCM does not supply voltage for the speedo. It receives the same signal from the VSS that the speedo head does. The PCM then uses that signal for CC and OD usage. Your problem is before the PCM. Check wiring and connections first. Check for voltage at the VSS plug. Check the wiring back up to the speedo head with a meter to determine if you have a problem in the wire. The VSS input to the PCM is threw pin #7.
