new (to me) truck, new turbo set up
Postby swank » Sun Feb 15, 2015 9:55 pm
Took a bit (had the truck seven years or so now) to get it around the block once. This is my favorite part so far though:
http://youtu.be/u4oniR-mzYQ
Still working on the controller, but it is well under way at this point.
A few little general things to finish up on the truck before I go register it, can't wait!! Soon to be back in your ranks!
truck
swank
Re: new (to me) truck, new turbo set up
Postby CumminsPower59 » Mon Feb 16, 2015 5:36 am
Wicked cool!
Postby dazedandconfused » Mon Feb 16, 2015 7:59 am
Very nice. Hope to see it working with a controller soon.
Postby Remps » Mon Feb 16, 2015 10:15 am
Wow. 8) can't wait to hear how it runs once you get it tuned up.
Postby ellis93 » Mon Feb 16, 2015 11:32 am
I'd love to hear that run 8)
Postby RCCUMMINS89 » Mon Feb 16, 2015 11:34 am
8) Any other vids yet?
Postby swank » Mon Feb 16, 2015 1:53 pm
Here's another video of the truck actually running. I'll have to get somebody to help so the engine noise doesn't overpower everything. It sounds way cooler when you're a couple feet away from it.
http://youtu.be/TTnUZRgMdSU
truck
swank
Postby oldestof11 » Mon Feb 16, 2015 5:19 pm
I'm.assuming the top is a 351VE, what's the bottom one?
Postby swank » Mon Feb 16, 2015 5:51 pm
It's actually a 451 and a 551.
truck
swank
Postby DMan1198 » Mon Feb 16, 2015 8:13 pm
So is it the 64mm 451 or the smaller one?
Postby swank » Tue Feb 17, 2015 4:12 pm
It's a 60mm inducer.
truck
swank
Postby DMan1198 » Tue Feb 17, 2015 5:23 pm
Ok, so a bit bigger turbine side than the 351ve. Very cool setup for sure. Are you going to set it up for exhaust braking as well?
Postby swank » Tue Feb 17, 2015 5:35 pm
That is the plan. And also have a feature where it auto-cycles the mechanism every time it returns to idle or something, so that it scrapes any soot buildup off the center section.
truck
swank
Postby DMan1198 » Tue Feb 17, 2015 7:07 pm
That's a good idea. I ran a lot of heat through my 351ve, and was constantly cycling the exhaust brake. When I took it apart after my s400 swap it was pretty clean. Just a light coating of soot that's normal on any diesel exhaust component
Postby swank » Tue Feb 17, 2015 7:52 pm
Good to know. What were you using to control it?
truck
swank
