AFC fix
AFC fix
Postby brandonmgreer » Sat Mar 07, 2015 4:00 pm
Can anyone tell me the drillbit and tap size to put a compression fitting on the AFC top? Mine broke yesterday.
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
Re: AFC fix
Postby oldestof11 » Sun Mar 08, 2015 5:39 am
Are you talking about where the boost reference line goes? Its a metric size but quite a few people tap it out for 1/4” NPT.
Re: AFC fix
Postby brandonmgreer » Sun Mar 08, 2015 1:14 pm
Yes. The nuts on the IP came loose, and the go st reference tube broke while it was moving around. I was Donna put truck fittings and 1/4" poly line in its place.
brandonmgreer
Re: AFC fix
Postby brandonmgreer » Sun Mar 08, 2015 1:15 pm
^^^boost reference tube
brandonmgreer
Re: AFC fix
Postby Tacoclaw » Sun Mar 08, 2015 4:57 pm
I think I screwed an 1/8" fitting straight into mine, either that or the head. Just ran an 1/8" NPT tap into the other one, no drilling needed.
Re: AFC fix
Postby dazedandconfused » Sun Mar 08, 2015 5:11 pm
The head is 1/8" fitting and you have to tap the pump top to 1/8" npt. I picked up two heavy duty air line fittings and a piece of poly airline.
Re: AFC fix
Postby brandonmgreer » Sun Mar 08, 2015 6:12 pm
Thanks guys. Yes, the head is an 1/8 NPT thread. The AFC cover I put in the vice, and drilled/tapped to accommidate the 1/8 NPT fitting.
The bit size is 21/64 to tap for an 1/8.
If anyone does this in the future, a good sharp tap is needed, or it will bugger the hole trying to start it. Bought a new tap, it went easy as pie. Another excuse for new tools, right?
Sorry for the spelling earlier, my fat fingers don't do so well on the phone.
brandonmgreer
Re: AFC fix
Postby RCCUMMINS89 » Sun Mar 08, 2015 9:22 pm
Glad you got it up and running.
Re: AFC fix
Postby brandonmgreer » Sun Mar 08, 2015 10:37 pm
It still ran, Eric, just not very good, and was doing some weird stuff. One of these days, I'll get caught up, and we'll get this build started! I'm brewing a new idea... mwahaha :grin:
brandonmgreer
Re: AFC fix
Postby dpuckett » Fri Mar 27, 2015 9:30 pm
A 1/8" compression union will fit in the AFC housing quite well. Run a 1/8npt to 1/8" compression fitting adaptor from he head. Run some 1/8 air line in the middle. There is some debate as to whether the 1/8 line is too restrictive, but I never had any issues.
Users browsing this forum: No registered users and 66 guests
