3.2MM camplate on way.
Postby RCCUMMINS89 » Mon Mar 30, 2015 1:17 pm
With the help of Oldestof11, we (ok he) found out a part number for a 3.2mm Bosch camplate. So I decided to bring 2 of them in. Going to check the ramp profile on it and see if we can gain a little more fuel.
If anyone else is interested in trying the other one, let me know.....
Re: 3.2MM camplate on way.
Postby oldestof11 » Mon Mar 30, 2015 2:18 pm
Woohoo!
Honestly, my internet ninja skills met a lil green leprechaun who showed me the way to a black hole beyond the internet that brought me to....
Ok, I found a pump number with it, Eric found the part.
Postby ellis93 » Mon Mar 30, 2015 2:31 pm
Pm me a dollar amount and we'll talk about it. I'm looking for something to help out with the chevy/24valver. Couldn't hurt either.
Postby DMan1198 » Mon Mar 30, 2015 3:45 pm
I'd also be interested in one of these
Postby RCCUMMINS89 » Mon Mar 30, 2015 4:10 pm
We shall see how the ramp is and how it does in the upper rpm fueling.
The pump application that this comes from: 7.3l inline 6. 12mm/3.2mm ve. 5x10 injectors set at 278 BAR, 90cc of max fueling, 158 peak hp, and 2300rpm governed.
Postby dazedandconfused » Mon Mar 30, 2015 5:52 pm
I wonder if the added rpm we use will cause and issue?
Postby RCCUMMINS89 » Mon Mar 30, 2015 6:14 pm
Potentially...
Postby DMan1198 » Mon Mar 30, 2015 8:59 pm
Have you had one of those 4mm camplates in your hands? I've kind of been wanting to try one of those. I was considering doing a 4mm on a 6.4 cummins project I have planned
Postby RCCUMMINS89 » Mon Mar 30, 2015 9:11 pm
No, I haven't.
Postby Remps » Tue Mar 31, 2015 10:57 am
Awesome find guys. 8)
Postby RCCUMMINS89 » Thu Apr 02, 2015 5:39 pm
Went and picked up the cam plate today. I've got to have my Bosch supplier double check the numbers. As I'm showing the exact same amount of lift on this cam plate as the factory one.
Postby RCCUMMINS89 » Fri Apr 03, 2015 8:35 pm
Double/triple checked everything. I don't care how you swing it, the stock cam plate is measuring the same as this 3.2mm cam plate. Bosch lists ours as a 2.8, but it measures out just slightly under for me (3.12ish) and this 3.2 is measuring exactly the same for me.
So........yea...........
Postby fatty » Fri Apr 03, 2015 10:22 pm
Well, poo. That's disappointing.
Postby PToombs » Sat Apr 04, 2015 5:19 pm
That's strange, I wonder what is different for it to have a different part number.
Sounds like Jon screwed up, situation normal there. :mrgreen:
Postby RCCUMMINS89 » Sat Apr 04, 2015 5:36 pm
Jon provided me with the literature of an engine that contained a pump that had a 3.2 mm cam. (Sounds like, my brother's friend's cousin's fiance knew a guy).
The pump is listed as a 12/3.2 Where as ours is listed as a 12/2.8 Either way...... I think I'm going to try and swap it.
The ramp profile on ours is slightly different. This one is more of what I think would help give a faster rate..... but it is very minor stuff.
