timing question
timing question
Postby andyheins » Wed Apr 08, 2015 4:10 pm
the front cover is leaking on my truck and im wanting to reseal it, and while i was in there i was going to jump a tooth on the pump. my question is that i already have the pump to the head so doing the tooth jump and having the pump to the head be to much timing for it? its my dd. 90 non i/c 5 speed
1990 dodge 2wd 5 speed, 135,000 mile, h1c with 12cm housing, basic pump mods
andyheins
Re: timing question
Postby BC847 » Wed Apr 08, 2015 4:35 pm
Just pull the pump away from the head and then advance as needed.
Re: timing question
Postby Remps » Wed Apr 08, 2015 7:46 pm
Don't forget the kdp while you are in there. Doesn't hurt to check the torque on the other bolts inside the case.
Re: timing question
Postby andyheins » Wed Apr 08, 2015 9:45 pm
yeah i was gonna do the kdp and re-torque the head bolts while i got it apart. any idea on how many degrees jumping a tooth gains?
andyheins
Re: timing question
Postby Hansen01 » Thu Apr 09, 2015 6:23 am
Think its like 10
Under construction...
Hansen01
Re: timing question
Postby andyheins » Sun Apr 12, 2015 9:47 am
10-4. thanks for the information
andyheins
