Piston-to-wall clearance?
Postby Begle1 » Wed Jun 10, 2015 11:55 am
I'm dropping my block off in a couple days to get resurfaced, O-rings and bored out for .020-over pistons.
What do I want my piston-to-wall clearance to be? I'm planning on using whatever piston rings Interstate McBee sent with their rebuild kit.
Keep it stock with maybe a bit on the tight side?
Re: Piston-to-wall clearance?
Postby burnt_servo » Wed Jun 10, 2015 11:31 pm
if the motor was stock , running it a hair tight would be fine .
but if your going to hotrod it at all , or mod the governor , ( or both ) you will want to run it looser than stock .
the extra heat from modding the engine will cause the pistons to expand more than stock , and at higher rpms you will want a touch more clearance to keep the piston from scuffing .
on the other hand , if you go too loose , the piston will rock too much causing the rings to wear out a lot quicker than normal .
most piston manufacturers give several sets of clearances depending on what you want to do with the motor .
'93 w250 .... stock ...
burnt_servo
Postby Begle1 » Fri Jun 12, 2015 6:33 am
Sounds like I should hit stock spec then?
Users browsing this forum: No registered users and 69 guests
