Who sells a good flexplate?
Postby Begle1 » Mon Jun 22, 2015 3:53 pm
I have the double-thick flexplate I bought from PATC about 7 years ago that was too thick to work. I have a non-lock-up 518 that I think has the same bell-housing as the stock 727, with a Goerend non-lock-up converter.
What are my options for flexplates?
Re: Who sells a good flexplate?
Postby RCCUMMINS89 » Mon Jun 22, 2015 4:28 pm
Phil at DPC sells a flexplate that is not a billet style...... runs them on 1000+hp trucks. I'd give him a call
Postby fatty » Mon Jun 22, 2015 6:43 pm
You can also buy a bell housing spacer that lets you run a thicker flexplate. I bought mine from PATC.
Postby Begle1 » Tue Jun 23, 2015 9:50 am
RCCUMMINS89 wrote:Phil at DPC sells a flexplate that is not a billet style...... runs them on 1000+hp trucks. I'd give him a call
Who is Phil at DPC?
Postby fatty » Tue Jun 23, 2015 10:40 am
Dieselperformanceconverters.com. Phil Taylor is the owner, he goes by "slowpoke" over on CompD. Best converter builder in the industry. I've got one of his converters and its great!
Postby Begle1 » Tue Jun 23, 2015 11:00 am
I called Phil and asked for a flexplate for a 1st gen Dodge Cummins, he said he didn't have one.
What is it I need to ask for?
Postby RCCUMMINS89 » Tue Jun 23, 2015 12:39 pm
? Beats me. I wonder why his flex plates won't work on a 1st gen? Did he say by chance?
Postby fatty » Tue Jun 23, 2015 2:02 pm
Most likely because it's too thick. My brother and I have the same flexplate. His fit fine in his 2001 and mine needed a spacer in my 1991.5.
Postby Begle1 » Tue Jun 23, 2015 4:02 pm
I guess I'll break down and get a spacer.
Only problem is then I'll probably need to re-do my super ultra custom transmission mount and I might need to get my drive-shaft re-tubed...
Postby Tacoclaw » Tue Jun 23, 2015 4:25 pm
I've got one of the solid, non-IC'd flexplates you can have if you want it, Begle.
Postby Begle1 » Tue Jun 23, 2015 5:15 pm
They made stock solid ones or is this an aftermarket one from somewhere?
I'm so confused... But I'd take it if it's stronger than the stock one I have.
Mine has holes in it...
Postby Tacoclaw » Tue Jun 23, 2015 7:30 pm
It's stock, but I just saw your sig says 90. You may have the same thing.
Here's a pic of it, no idea on its strength capabilities.
Postby fatty » Tue Jun 23, 2015 8:51 pm
Begle your mount might still be OK. The spacer I got is only 1/8"-3/16" thick.
Postby Begle1 » Wed Jun 24, 2015 5:34 am
You know, that does look like my flexplate come to think of it... I don't think it did have holes.
Maybe the new one I got was what had holes...
I'll get a spacer.
