2nd gen intke horn on 1st gen?
Postby jmos4 » Sun Feb 07, 2016 12:29 pm
Hi all,
Gathering a little information about adding a intercooler on a 89 truck and was thinking of getting a 94-97 intake, will it bolt on directly or do I need to change the intake plate?
Will the stock grid heater work?
Regards,
Jim
1992 Dodge 250 4 x 4
currently 360 TBI
NV4500, NP241
Dana 60's 4.10 gears
soon to be Cummins powered
1989 D250
Cummins NV4500 (Donor)
jmos4
Re: 2nd gen intke horn on 1st gen?
Postby PToombs » Sun Feb 07, 2016 5:14 pm
Yes, it will bolt right on and you can keep the heater. On an '89 I think you have to turn the intake plate around.
Postby Philip » Sun Feb 07, 2016 5:21 pm
The 2nd gen 24 valve intake horns do not have the big support wing on them. They will work also.
Do not use a 3rd gen intake horn. It is very restrictive inside.
Here is a pic of a 2nd gen 24 valve air horn on my truck.
Postby CumminsPower59 » Mon Feb 08, 2016 11:11 am
You can run the intake plate in the stock location, you'll have to cut the "leg" off the intake horn. Here is what is on my truck, taken when I was mocking everything up.
All of the 2nd gen intercooler tubing, hoses, etc will fit right in...
I did have to notch the battery tray a little so that the tubing pictured above would fit without rubbing...
Users browsing this forum: No registered users and 66 guests
