Exhaust housing hx40 to hx35
Postby ellis93 » Mon Mar 21, 2016 11:35 am
Looking at a 62mm hx40 turbo with an 18cm housing. I do not want the 18cm housing but have a hx35 12 and another 14cm housing.
My thoughts here......I want to machine out the 35housing to fit the 40. Is it do-able?
Re: Exhaust housing hx40 to hx35
Postby ellis93 » Tue Mar 22, 2016 4:56 am
Seems there are two different exhaust turbin/shaft assemblies for the hx40. One being 67mm the other 65mm. One being 12blades the other 10. The number of blades are not specific to the mm diameter either. I've found both diameters in either number from multiple sources.
And since I can not get the seller to message me back.....I'll give this the finger,and move on to a rebuilt 35 with a new turbin/shaft and a 60mm compressor.
Postby ellis93 » Tue Mar 22, 2016 6:06 am
might just move onto something different
http://www.ebay.com/itm/NEW-Borg-Warner ... hw&vxp=mtr
Postby DMan1198 » Tue Mar 22, 2016 9:03 am
Might as well just get a 62sxe then
Postby ellis93 » Tue Mar 22, 2016 10:52 am
I'm just wondering how that open T4 housing will spool.
Postby DMan1198 » Tue Mar 22, 2016 1:24 pm
Probably quite slow. Looks like there's the option of a .91 divided t4. that'd spool quicker than the .88 undivided, but it still wouldn't be that quick
