custom ground fuel pin
Postby cumminsram » Sun Jan 28, 2007 12:45 pm
Does Anyone out there make custom ground fuel pins?For instance possibley one that would be worth more hp than the bully dog pin or the old smokey pin.
Thanks in advance.Jess
03 duramax reg cab 4x4 6sp blue, daily driver
93 w350 reg cab 4x4 5sp single wheel
sold: 1993 auto 4x4
SOLD:1990 power ram 250 4x4 5sp
cumminsram
Postby 92 D/UNIT » Sun Jan 28, 2007 1:36 pm
from what i understand, old smokey did all of the R&D to develope the pin. and bully dog just copied it.
Brian 92 D 250 250K, A518, pump mods, BHAF, 4X15s, 4" turbo back dual exh, 3200 spring, HTB2 62/12.
SOLD 92 w250 ex cab, 5 spd, 3.54, 320,000, WH1E 14, Fuel pin, pods,shortened 4200 gs, Bhaf, 4" turbo back
388/886
92 D/UNIT
Postby cumminsram » Sun Jan 28, 2007 1:59 pm
So on your truck did you ground one yourself or buy one?
sold: 1993 auto 4x4
cumminsram
Postby 92 D/UNIT » Sun Jan 28, 2007 2:01 pm
i ground mine myself.
388/886
92 D/UNIT
Postby cumminsram » Sun Jan 28, 2007 2:05 pm
What does that entail. Do you just start taking some back in a v notch pattern? Did you get a better power curve by doing your own?
sold: 1993 auto 4x4
cumminsram
Postby 92 D/UNIT » Sun Jan 28, 2007 2:38 pm
i experimented with it quite a bit, im not sure what the proper way was, i just started grinding and testing ended up making it worse then stared from scratch until i found what worked best.
here is one i did for a friend, dont know if this was the best profile but worked nice on his truck.
http://i124.photobucket.com/albums/p36/ ... nstock.jpg
http://i124.photobucket.com/albums/p36/ ... ground.jpg
388/886
92 D/UNIT
Postby 2stroke » Tue Jan 30, 2007 10:40 am
do u have a better pic from the front side?
2stroke
Postby dpuckett » Tue Jan 30, 2007 11:21 am
92D/UNIT- that is about what mine looks like. Mine has a little steeper profile on the lower end to cut smoke, but with a loose spring, it spools pretty well.
2stroke- the profile is what makes the power increase. You can start where ever you want- I even did one for a guy that started on the LEAN side, and went up to about the stock max. I start mine at about middle or a little toward the lean, then Dremmel it out til I like the side view.
DP
Postby 2stroke » Tue Jan 30, 2007 5:01 pm
looking at pics of this one compaired to pics of Wannadiesel`s. they are pretty different as far as how it was cut into deeper down the shaft. is this needed? anyone else have pics of thier custom ground pins?
http://www.dieseltruckresource.com/dev/ ... t=fuel+pin
2stroke
Stock pin..
Postby Flanra » Wed Jan 31, 2007 2:48 pm
Does anyone know where a fellow could get a spare stock pin?
1990 1st gen, 727 auto, starwheel bottomed, fuel delivery rate adj. fuel screw turned, 4" exhaust/stacked, pyro/boost 35# @ 1250*... 3" lift 36" tires...
http://s119.photobucket.com/albums/o151/flanra/Truck/
Flanra
Postby JLeonard » Wed Jan 31, 2007 3:07 pm
I ground mine more like 92D did...except more agressive on the lower to mid section...sounds like how Daniel ground his.
Then I polished it a bit.
I'm sure I could go more, but it works pretty good as it IMO.
91 D250 w/modified Cummins, 89 D250 donor (future boat engine)
JLeonard
Postby 2stroke » Wed Jan 31, 2007 6:56 pm
so the trick is to make the "cone" thinner so the pin in the pump can push out furthur for more fuel right? but on Wanna`s cone it looks like the pin may be allowed to ttravel even furthur?
2stroke
Re: Stock pin..
Postby 92 D/UNIT » Wed Jan 31, 2007 9:43 pm
Flanra wrote:Does anyone know where a fellow could get a spare stock pin?
i went to buy a used one from a local inj pump shop and the guy wanted 100.00 :o
388/886
92 D/UNIT
Postby 92 D/UNIT » Wed Jan 31, 2007 9:49 pm
2stroke wrote:so the trick is to make the "cone" thinner so the pin in the pump can push out furthur for more fuel right? but on Wanna`s cone it looks like the pin may be allowed to ttravel even furthur?
wish i had a pic of mine to show you, but its pretty agressive i actually welded up the other side on the stock profile to make it steeper and deeper.
i know im a little extreme but when you only have so much $$ to spend and time on your hands with a shop full of tools you do that kind of stuff, at least i do
388/886
92 D/UNIT
Postby Flanra » Wed Jan 31, 2007 10:36 pm
$100?! :shock: Thats crazy. Are they out of their mind? Wow what I would give to work in a machine shop again.... Do you think some cold rolled round stock would be good e'nuff to make a pin out of?
Flanra
