5 inch exhaust
5 inch exhaust
Postby 93DodgeCummins » Sun Apr 04, 2010 11:54 am
does anyone know if there is a 5 inch exhaust system made for the 1st gen cummins pickups?
93 Dodge W250 4X4, Custom air intake, Diamond Eye 4 inch turbo back straight pipe exhaust, HX-35W with Banks upgrades, KDP fixed, Getrag 5 speed, Isspro Tach, pyro, fuel pressure, and boost. Raptor 150, 3200 rpm spring, Power Screw in 1 turn, aftermarket fuel pin
93DodgeCummins
Re: 5 inch exhaust
Postby peobryant » Sun Apr 04, 2010 12:38 pm
I've never heard of anyone offering a 5" system. I believe there are a few people running 5" systems, but they made them themselves. Why do you want a 5" exhaust anyways?
Re: 5 inch exhaust
Postby 93DodgeCummins » Sun Apr 04, 2010 2:38 pm
just wondering because my buddy has one on his 99 dodge cummins and i really like the sound
93DodgeCummins
Re: 5 inch exhaust
Postby burnt_servo » Sun Apr 04, 2010 3:35 pm
run a 4 inch till you get past the transmision crossmember , then goto 5 inch .......
'93 w250 .... stock ...
burnt_servo
Re: 5 inch exhaust
Postby peobryant » Sun Apr 04, 2010 3:54 pm
93DodgeCummins wrote:just wondering because my buddy has one on his 99 dodge cummins and i really like the sound
You'll probably have to make it yourself, but I have heard (on DTR I believe) that you can modify a 2nd Gen exhaust to fit on a 1st gen, and I know they make 5" systems for 2nd Gen's. A 4" system on these trucks is tight (especially on 4wd trucks) so a 5" is really pushing it.
Maybe go ask on DTR about modifying a 2nd Gen exhaust, because as far as I know no one here has done it, and I have no personal experience.
Re: 5 inch exhaust
Postby 93DodgeCummins » Sun Apr 04, 2010 4:26 pm
well when i get the money im going to get a 4 inch turbo back then. I think bullydog makes a turbo back
93DodgeCummins
Re: 5 inch exhaust
Postby burnt_servo » Sun Apr 04, 2010 6:49 pm
to put a 5 inch exhaust in you need to massage the firewall / bottom of cab and open up / modify the transmision cross member .
even a 4inch exhaust will be a very tight fit through the cross member , and may rattle even if things are done right .
i believe cummins king has pics posted around here somewhere where he massaged the floor of his cab to fit a 5 inch exhaust .
burnt_servo
Re: 5 inch exhaust
Postby 1STGENFARMBOY » Sun Apr 04, 2010 6:56 pm
dang i just took off my homade 5in( from the back of the cab on out ) 30 min ago and
put my 5in stacks back on i wish i would have takin a pic of it on the truck, my complete
system is homade 4in turbo on out. i will try to get pics of boyh systems tomorrow night
and post them. ;) and it does sound great and its suprisingly quiet, with the 5in tailpipe
Dar
Re: 5 inch exhaust
Postby AHineman » Mon Apr 05, 2010 6:30 am
I agree, on a four wheel drive it would be much easier to make it 4" until the back of the cab and then 5". I've got a Stans 4" downpipe and an Expandit 5" 2nd gen kit on my two wheel drive. I had to use a short piece of flex after the downpipe to keep from hitting the crossmember, and I had to make my own hangers, but it looks and sounds great. It did take a little time to get it just right over the axle and around the shock because there is not much room to play with and I had to cut 6 or so inches off the end of the tail pipe. I got the Expandit kit from Dieseldawgs.com for $289.99 or so with free shipping, but after I bought it they ran a sale on it for $20 less. Haven't looked lately though. 8)
Re: 5 inch exhaust
Postby peobryant » Mon Apr 05, 2010 8:50 pm
AHineman wrote:I agree, on a four wheel drive it would be much easier to make it 4" until the back of the cab and then 5". I've got a Stans 4" downpipe and an Expandit 5" 2nd gen kit on my two wheel drive. I had to use a short piece of flex after the downpipe to keep from hitting the crossmember, and I had to make my own hangers, but it looks and sounds great. It did take a little time to get it just right over the axle and around the shock because there is not much room to play with and I had to cut 6 or so inches off the end of the tail pipe. I got the Expandit kit from Dieseldawgs.com for $289.99 or so with free shipping, but after I bought it they ran a sale on it for $20 less. Haven't looked lately though. 8)
So you're confirming that with a little modification a 2nd Gen exhaust can be run on a 2wd 1st Gen? Should open a few more, cheaper doors for people in the market for exhausts if I read your post correctly. If that's the case, I wonder why so few people offer 1st Gen exhausts...?
Re: 5 inch exhaust
Postby AHineman » Tue Apr 06, 2010 8:16 am
Yes, with little modification a 2nd gen kit fit on my 2wd getrag (using a Stans 4" downpipe). An auto trans may be wider and cause problems. If my downpipe came down a little longer I wouldn't have needed the short piece of flex. A portable bandsaw took care of the tail pipe being too long. If I can get my wife to let me crawl under my truck with her new digital camera, I'll try to post a picture or two this week sometime.
Re: 5 inch exhaust
Postby chrislib » Fri Apr 09, 2010 3:56 pm
I have a 5in from the t-case back, it`s all 2nd gen stuff. It fits fine but was definitely not bolt-in, then again the 4in that it replaced was`nt either.
It`s not about how hard ya hit...it`s about how hard ya can GET hit and keep movin forward.
93 W250 CC 4x4, Auto,7x010`s, D-Zilla/16cm, 5in exh, BHAF/Smoky...don`t call it ratty, that`s patina son!
chrislib
Re: 5 inch exhaust
Postby The_Head » Fri Apr 09, 2010 7:57 pm
Did it help to go from 4" to 5"? I was told it does, because it's the total volume of the exhaust system that matters. Yes? No?
The_Head
Re: 5 inch exhaust
Postby Richie O » Fri Apr 09, 2010 8:04 pm
I have all of it covered on my 93. 3 to 4 to 5. :D
Re: 5 inch exhaust
Postby PToombs » Sat Apr 10, 2010 5:57 pm
4inch is plenty big right up to around 500 hp. Over that you may want to up size a little.
