Will a 12 cm w/g housing exhaust as well as a 18 cm housing?
Postby Begle1 » Sun Jul 08, 2007 9:57 am
I was putting my pump back together and realized that I forgot the idle screw. So the solution was to turn the fuel screw up to the point where I didn't need the idle screw. :twisted:
Would a 12 cm housing with a wastegate be better able to manage EGT's as an 18 cm housing? Or is it possible to overwhelm the wastegate with a maxed pump and stock injectors?
Postby PToombs » Sun Jul 08, 2007 5:25 pm
You might be right on the edge with that. If you go with a 16 housing you get good spool, but not quite as fast. If you go bigger or have to tow anything it will not be as restrictive.
Postby wannadiesel » Mon Jul 09, 2007 1:57 pm
If you're OK with the spoolup, stick with the 18 unless boost is over 35 psi.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Mon Jul 09, 2007 2:14 pm
I can just peak my 35 PSI boost gauge.
So if I were to go to a 12 cm w/g housing, I would overwhelm the wastegate and see higher EGT's and boost at the top end?
Postby wannadiesel » Wed Jul 11, 2007 4:35 pm
You'd see a little more EGT with the wastegate working. With it blocked EGT and boost would be higher. It sounds to me like your setup is pretty well balanced right now with the 18.5.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Sat Jul 14, 2007 7:16 am
With the wastegate blocked the EGT's would be totally unmanageable, right?
Wasn't there a How-To on drilling out the wastegate to make it flow better? I'd really like the fast spool-up, if for no reason but to control my smoke.
Postby wannadiesel » Sat Jul 14, 2007 8:30 pm
Without the wastegate you'd see 40+ psi of boost, which is just going to be hot air.
To wastegate all 6, just grind a notch in the divider or drill a hole in it through the wastegate port.
Best dyno: 408/844
wannadiesel
diesel guru
Postby Begle1 » Sun Jul 15, 2007 8:18 am
Wouldn't a notch or hole reduce the top-end restriction back down to 18.5 cm levels?
Postby wannadiesel » Mon Jul 16, 2007 4:52 pm
No. All the exhaust still has to pass though the little slots by the turbine.
Best dyno: 408/844
wannadiesel
diesel guru
Postby mhuppertz » Wed Jul 18, 2007 3:30 pm
If you are wrapping the engine higher because of a GSK, I think the 12cm would get very restrictive.
mhuppertz
Postby Begle1 » Wed Jul 18, 2007 3:38 pm
I burn 75% of my fuel at speeds above 65 miles per hour, so I probably shouldn't get the 12 cm housing...
So what are my alternatives? An external wastegate in addition to the one on the housing?
Postby mhuppertz » Wed Jul 18, 2007 6:15 pm
At your altitude I would think a 16cm would work best.
mhuppertz
Postby wannadiesel » Thu Jul 19, 2007 4:04 pm
Stick with what you have and bump the timing some.
Best dyno: 408/844
wannadiesel
diesel guru
