Swapping in another cam....
Re: Swapping in another cam....
Postby BC847 » Sun May 27, 2012 7:44 pm
onefourx wrote:Difference between cal trac type bar and your current anti wrap bars is cal trac will let the suspension work, the anti wrap bars probably bind during travel
I had forgotten about that!
I've actually been contemplating the Caltracs for a couple of years now. It's just that now I'm at a point where I've got to actually do something now.
Pete, I'm gonna be toying with the air pressure.
I appreciate the input fellas. 8)
Postby Tacoclaw » Sun May 27, 2012 10:17 pm
Since the Caltracs use the same mounting points, or at least really close to them, they will be parallelogram. Being that, it shouldn't affect the suspension at all, since it's literally moving in the same arc as the normal setup.
That's why Caltracs are so good, there's no angles to figure out on them.
Postby BC847 » Sun May 27, 2012 10:29 pm
I've got to do something with my springs. I know the ends of the leafs have worn into the leaf above, on the front spring-packs. I could loose a leaf or two in the rear . .. . . . . . need to get new springs made anyway . . . . . . . .
Crap!
Postby dazedandconfused » Mon May 28, 2012 4:35 am
Nothing like handling out cash hand over fist to help improve the improvements you just made. :D
Postby RCCUMMINS89 » Mon May 28, 2012 7:11 pm
dazedandconfused wrote:Nothing like handling out cash hand over fist to help improve the improvements you just made. :D
:lol: That is the diesel man's moto imo. Every other month we all buy something to replace the thing that we just bought that was needed to fix the problem we just created by buying the other part that was going to be the end all of end all buys to finish the project.
Postby tampabayBill » Mon May 28, 2012 8:12 pm
AMEN !!
Twins coming soon!
tampabayBill
Postby BC847 » Thu May 31, 2012 8:36 pm
Well, apparently I can't launch at 2200rpm with 25psig of boost as when I hit it, the boost jumps immediately to 58ish and the wheels spin in the 60' (1.86).
If I launch at 2000rpm at 18ish psig of boost, there's a slight delay before the boost jumps to 58ish and with that, the wheels don't spin (break traction) in the 60' (1.72).
I also have the W/M come on a little later FWIW.
Didn't break anything, going to the beach tomorrow. 8)
I'm thinking of rigging a boost activated adjustable pressure switch that will illuminate a dash mounted light when I get to . . . . say . . . 20psig.
Postby Tacoclaw » Thu May 31, 2012 8:44 pm
Sooooo, is this a good thing or a bad thing?
It's obviously good you didn't break anything, but what's the story/your opinion on the cam?
Postby BC847 » Thu May 31, 2012 8:52 pm
Tacoclaw wrote:It's obviously good you didn't break anything, but what's the story/your opinion on the cam?
Well, I'd say my goal of moving the apparent power to the left a little has been met. I just have to learn how to deal with it.
My thoughts are with the VE being all business in the lower engine rpm, then this cam complements that by having the charge-air come on a little earlier (as compared to that 181/210 cam removed) thus making better use of the low rpm fuel.
I think it'd be wise to consider what you wrap around the cam (ported head, free-flowing IC & plumbing, turbo(s), fuel, timing, etc) when one considers the thought: "Your mileage may vary". Clear as mud?
Postby AHineman » Mon Jun 11, 2012 8:07 pm
BC847 wrote:I'm thinking of rigging a boost activated adjustable pressure switch that will illuminate a dash mounted light when I get to . . . . say . . . 20psig.
Napa 701-1575 is the pressure switch I've got to activate my KSB at 20psi of boost. 20psi is about the max for it to consistently make and break. They make some that work for higher pressures, but the dead bands are bigger than I would like. I had mine on a Druck at work and it was changing states at 19.3-19.7 psi.
It is adjustable. Pop the rubber cap off the end and there is an adjustment screw.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=BK_7011575_0361175264
You may find something that would suit you better on Napa's website, I had no luck at the store. They didn't even know they sold them until I gave them a part number. :lol:
Postby directinjktn1stgen » Wed Sep 19, 2012 5:43 pm
im thinking on your suspension coilover in the rear and 4 link 8) thatll fix it and ride really good and elminate those silly leaf springs :wrench: and always if it dont im guessing tub it out with cut axle and drag slicks :cheers:
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Users browsing this forum: No registered users and 395 guests
