new parts
new parts
Postby dunes450r » Thu Jul 12, 2012 8:52 pm
http://www.quad4x4.com/tk2001.html
this should be arriving tomorrow! gonna have some work to do in a few weeks. anyone ever done the conversion for a small bearing 205 to a large bearing?
dunes450r
Re: new parts
Postby txs » Tue Jul 17, 2012 10:00 am
Seems i remember Bill and Phillip were collaborating on this, after bore job on tc case there was no case material for the seal.
txs
Re: new parts
Postby dunes450r » Tue Jul 17, 2012 9:15 pm
ruh roh.......well i'm find out next month some time when i tear into it :grin:
might be machining a new seal retainer too.....
dunes450r
Re: new parts
Postby ahale2772 » Wed Jul 18, 2012 8:44 am
"All other NP205 models used a smaller diameter input bearing."
its not going to work... you need the 29 spline case, the 23 cant be feasibly converted.
why spend nearly 500$ on just parts when a 29 spline case can be had for less money?
Re: new parts
Postby dunes450r » Fri Jul 20, 2012 7:48 pm
ahale2772 wrote:"All other NP205 models used a smaller diameter input bearing."
you can convert the small bearing case to the larger, i'm going to bore my case to the larger diameter.
and
1. i couldn't find a 29 spline case in my area for under $600-$900
2. my family owns a machine shop, so boring the case will cost me nothing.
3. i know the transfer case that i currently have is very sound, has had routine maintenance and has never been run out of oil etc
4. i was thinking about just running the 23-29 spline coupler but was advised against it
dunes450r
Return to Transmission
