Dirtfloorfab's DEM suburban/pickup conversion and 12v swap
Re: Dirtfloorfab's DEM suburban/pickup conversion and 12v swap
Postby bighroder » Mon Oct 01, 2012 5:43 pm
getting closer to gear jammin
86 suburban/pickup conversion project "Dont Even Matter"
Dana 60, 14bff, 12v ve, nv4500, np205
http://1stgen.org/viewtopic.php?f=32&t=13252
bighroder
Postby PToombs » Tue Oct 02, 2012 5:01 pm
That don't look anywheres near close to me! :jumpsmile:
Postby bighroder » Wed Oct 03, 2012 7:44 am
4x4 main shaft is on order and ill have to restack the gears and get an output housing and bell, and its closer then no trans
bighroder
Postby bighroder » Tue Oct 09, 2012 4:56 pm
Havent even welded the engine stand up yet and my dads bitchen about it being in his garage
bighroder
Postby bighroder » Sun Nov 11, 2012 2:26 pm
Engine on the stand
bighroder
Postby bighroder » Mon Nov 12, 2012 7:35 pm
Cleaning, and doing the lo buck no $ mods I'm really going for 400 horse in wondering what turbo setup would be good I've really been wanting to run compounds but I don't think there is a setup I can use with the h1c? I've heard good things about the hx35/ht3b setup but then I would have to buy 2 turbos? What injectors should I be going four pods really arent much bigger then my stockers and I dont want to brake the bank. Any suggestions opinions are appreciated
bighroder
Postby bighroder » Tue Nov 20, 2012 5:57 pm
Just because I thought it was hilarious, cummins powered toter truck
Stripped everything off for cleaning, waiting on a battery to start
bighroder
Postby bighroder » Fri Nov 23, 2012 11:25 pm
bighroder
Postby bighroder » Sat Dec 08, 2012 11:41 pm
Still waiting on my high pressure turbo but I'm polishing my low pressure turbo, 1st stage
bighroder
Postby bighroder » Thu Dec 20, 2012 12:19 pm
Twins ;)
bighroder
Postby bighroder » Thu Dec 20, 2012 4:29 pm
bighroder
Postby 12vsuburban » Thu Dec 27, 2012 5:35 pm
Great build. Im about to start a '69 suburban build.,
12vsuburban
Postby dustin_mud » Fri Apr 19, 2013 4:22 pm
Cool build.
dustin_mud
Postby Knoberman » Mon Jun 24, 2013 5:05 am
cool!, how's it coming?
92 Cummins& a 518. installed in a 86 cclb f350 4x4
Knoberman
