flashgordon wrote:If you can bleed the injectors and it starts..........I wound be looking for a air leak. in the suction and return lines.
When I changed the lift (transfer) pump, I bled the fuel lines on the passenger side of the engine, right before they go into the head. I think that is where I'm supposed to bleed them, right? I would crack the fitting loose, crank the engine until I saw fuel, then tighten and go to the next one. Is that the correct procedure?
After doing all 6 lines, the truck fired right up and ran great, except fuel was leaking from the IP. (pictures below) I ran it for a little while, shut it off and went to bed. The next morning it fired right up but didn't leak anymore! It ran for about 35 minutes while I jockeyed trailers around my yard, then it quit running again. It hasn't run since.
Have you tried pumping the lever on the lift pump.............
Yes, and it didn't start.
Is it possible that you fuel gauge is off, and your out of fuel?
No. The truck has done it for a little while now...off and on. I usually wouldn't even do anything and it would sort of 'fix itself'!
It's probably you Injection pump, but i would be doing a lot of test to make sure you getting clean, air free fuel to the pump before you replace it.
I agree, but I'm not really sure how to test it. I'm trying to research the board, remodel my house, get a new job, raise a Great Dane pup, and please my wife all at the same time, and I mean 'please' her by doing all of the above!![]()
How long has it been since you replace your fuel filter?.......get any water out the drain?
I replace the air, fuel and oil filters every 10K miles. I also just replaced the fuel filter when I replaced the lift pump. No water.
Flash.
Begle1 wrote:One problem spot for leaks is the hard line that goes from the bleeder bolt to the injection pump; it is actually two lines bolted together, and the bolt tends to loosen up.
