84 d150 to 06 cr cummins
Postby 84dragtruck » Sun Dec 02, 2012 7:19 pm
Building a drag truck. It's an 84 d150 that had a big block 440 in it when I bought it. Question is I'm putting a fully built 06 cr cummins into it. Will I need to put a diesel core support in? Haven't figured out what I'm going to do for an intercooler for sure yet. Might do an air to air, might mount a water to air in the cab in place of the passenger seat, might not run one and just spray the heck out of it in the hot side going to the intake.
84dragtruck
Re: 84 d150 to 06 cr cummins
Postby hackster » Sun Dec 02, 2012 10:28 pm
You don't have to put a later cummins core support in there.....however if you do not your going to want one nearby to help with the mounts for the larger radiator that you need for the cummins.
I used the parts from a cummins truck and transferred them onto the 80 grille in my swap. Was a fair bit of work but I had a bent up cummins core support from a wrecked 93 and a descent one from the 80 with the headlight buckets in the right location.
Not sure if that helps at all.
Sean
hackster
Postby oldestof11 » Mon Dec 03, 2012 3:32 pm
Daily driver?
If so, I would get a diesel support and fit in an air/air cooler. If just a drag truck, you cannot beat air/water for IAT and power.
Postby 84dragtruck » Mon Dec 03, 2012 5:46 pm
Full out drag truck. Might see the street for a quick few mile rip but thats bout it. Also debating if I sink the rear cylinder to cylinder and a half into the fire wall for not only room in front of the engine but also to put more weight on the rear.
84dragtruck
Postby SuperiorRam » Mon Dec 03, 2012 5:50 pm
Might wanna do that J, mine don't hook for beans. And number one is behind front axle centerline in mine if I were to do it again it would be back further.
Thought it was Gunna be a "street toy"
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Postby oldestof11 » Mon Dec 03, 2012 6:06 pm
I would do the A2W then because you can locate all that stuff rearward to help with weight distribution.
Postby 84dragtruck » Mon Dec 03, 2012 6:09 pm
Ya. I'd agree with you there. But I'm also thinking of adding a second funny car cage so I can take people for rides down the track.
84dragtruck
Users browsing this forum: No registered users and 149 guests
