Timing questions
Re: Timing questions
Postby cummins12club » Sun Dec 09, 2012 6:46 am
Do any of u guys have time slips from the track showing how much difference just the ksb adds?
cummins12club
Postby oldestof11 » Sun Dec 09, 2012 9:31 am
I did at one point.
With an old truck that had the stock auto, I shaved .2 off in the 1/4 running a 16.3 compared to a 16.1. I also had a Walbro 392 fuel pump to help with the top end.
Postby cummins12club » Sun Dec 09, 2012 1:11 pm
Was ur auto stock or built? Did u have any slipping issues? Last season I ran 15.71 on just an hx35 all the pump work and a stock auto
cummins12club
Postby AHineman » Sun Dec 09, 2012 1:25 pm
Cummins12club, seems like you never read the WHOLE post. Says right there it was a stock auto.
Postby cummins12club » Sun Dec 09, 2012 5:19 pm
Sorry
cummins12club
Postby oldestof11 » Sun Dec 09, 2012 5:33 pm
The only thing done to the truck was 3200 rpm spring and the fuel pump. Mine was also 2wd so i could build boost at the line.
Postby cummins12club » Sun Dec 09, 2012 8:59 pm
Those are good numbers for a 2wd u have any traction issues even wo spooling it up?
cummins12club
Postby cummins12club » Mon Dec 17, 2012 11:30 am
AHineman wrote:For anyone who cares...
There are 72 teeth on the pump gear, but since the IP turns half the speed of the engine, it means 10 degrees per tooth instead of 5. ;)
This is what it will look like if you advance your timing by one tooth. Stock means the O and the E line up. One advanced means O and C lines up. Don't be like JQmile and retard it a tooth. :P
(turn your pump gear clockwise in relation to your cam gear to advance it)
This is the pressure switch I was talking about for my KSB. (on my intake horn) I got it from Napa for like $35 or so. You can pull the rubber plug out of the end of it and adjust the pressure it makes at. I used a Druck at work to set it and it makes at 19.4-19.7 or so psi. 8) This is the upper range at which you can set this switch. Napa carries others for different pressure ranges, but you need to check the deadband on them, as some have more than I would want. You can use these things to control solenoids for wastegates or whatever. ;-)
Part number 701-1575
http://www.napaonline.com/Catalog/Catal ... 0361129325
My vallet and ksb switch setup with LEDs for indication.
http://www.youtube.com/watch?feature=player_detailpage&v=JscJypDes1Y
how do u adjust the pressure switch to 20psi and do u recommend runing it w 1 tooth advanced?
cummins12club
Postby skilletky » Mon Dec 17, 2012 12:58 pm
at the end of the switch is a allen head screw usally. turn it in or out to adjsut it. with 5x18's i would put it +1 tooth and go from there. i got mine +1 and close to the head and it runs great, but every truck is different. i had the same pressrue switch set up and it was very nice, till the switch broke.
skilletky
Postby skilletky » Mon Dec 17, 2012 1:01 pm
cummins12club, i have the ip nut wrench to get to all the bolts if ya need to borrow it, dont know if ya got one or not, but it makes life alot easier.
skilletky
Postby BC847 » Mon Dec 17, 2012 3:31 pm
cummins12club wrote:Do any of u guys have time slips from the track showing how much difference just the ksb adds?
No time-slips but ... . .
What the KSB does to the injection event timing plot vs pump rpm . . . .
From the standpoint of performance, the effect of the KSB appears not so much about adding power as it is about moving the power around. Look at the changes from a given RPM point of view.
From recent testing of a new IP . . . . .
Postby cummins12club » Mon Dec 17, 2012 5:00 pm
skilletky wrote:cummins12club, i have the ip nut wrench to get to all the bolts if ya need to borrow it, dont know if ya got one or not, but it makes life alot easier.
I actually bought the tool from snap on :)
cummins12club
Postby rockmike » Tue Jan 29, 2013 1:34 pm
Some great info,very interesting graph you posted...I may have to play with this.X3 on the press. switch set up,GREAT idea!
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
