Whats better? Allison AT545RM or A518?
Postby oldestof11 » Wed Dec 12, 2007 2:06 pm
Ok which would be better? I know the Allison is a 4spd lock-up, non-OD, tranny but the A518 is a non-lock-up, OD tranny. What is better for a DD/drag/2wd puller? The draggin' and pullin' coming a couple of years later. Going into a 87 1500 Suburban :wrench:
Postby Begle1 » Wed Dec 12, 2007 7:19 pm
What's that Allison out of?
Postby oldestof11 » Wed Dec 12, 2007 8:06 pm
Big screaming yella zonker Blue bird :lol:
Postby Begle1 » Thu Dec 13, 2007 10:17 am
Well, the lock up would be more useful for pulling, towing and racing than overdrive would. You might need some higher-range gears in the differential, though.
If the Allison is any more heavy duty than the A518, it'd probably be the route you'd want to go.
Postby oldestof11 » Fri Dec 14, 2007 2:34 pm
Anyone else?
Also, how would a Chevy 10 bolt 2.73 hold up to about 300 hp? I am thinking (for now) just a turbo upgrade and getting my stock injectors rebuit. Maybe even a 12cm housing. OH and a BHAF.
Postby flashgordon » Fri Dec 14, 2007 4:14 pm
oldestof11 wrote:Anyone else?
Well a 14 bolt is comparable to a Dana 60.....posibly a 70
a 10 bolt would be like a Chry 8 1/4
I thing it would brake vary ease.
Flash.
flashgordon
Postby PToombs » Fri Dec 14, 2007 5:58 pm
IIRC, a 10 bolt wouldn't even hold up to a 350 sb with the juice! :shock:
It was cool for a couple minutes though! ;) :lol:
Postby GO OVRIT » Fri Dec 14, 2007 7:51 pm
It would be really cool if the 10 bolt has the factory gov-lock limited slip....It'll wait until you've got good boost before it explodes :shock: Then of course since its a c clip axle the shafts and wheels will come out. :evil:
GO OVRIT
Postby oldestof11 » Sat Dec 15, 2007 4:31 pm
Ok guys. I am going to bite the bullet. But still a little undecided. I know parts for the A518 is plentiful but what about the 545? I think being able to say "Yea, it has the Cummins and the Allison" would be a good coolness factor ;-) I am leaning more towards the Allison as it is cheaper by about $20. Plus in stock form the Allison can handle more.
Anything else?
Postby flashgordon » Sat Dec 15, 2007 5:17 pm
oldestof11 wrote:Ok guys. I am going to bite the bullet. But still a little undecided. I know parts for the A518 is plentiful but what about the 545? I think being able to say "Yea, it has the Cummins and the Allison" would be a good coolness factor ;-) I am leaning more towards the Allison as it is cheaper by about $20. Plus in stock form the Allison can handle more.
Anything else?
I just don't think, that there is vary fue,,,,if any of us that have dabbaled with that 545 Allison........but there are many that have dabbaled with a chry 727,518,618,47rh and 47re's
Flash.
flashgordon
Return to Transmission
