The Blue Goose
Re: The Blue Goose
Postby SuperiorRam » Sun Nov 11, 2012 7:39 pm
Mine took two years but I modded the firewall and trans tunnel rear leaf locations rear wheel tubs and engine location, so like Andy said take the time to do the mods you want to get in there. I know I skipped a few things like the hardened dana sixty axles and with a spool it's pretty scary knowing one could break and send me into the wall. it already sheared all stock the wheel studs off (that was interesting).
I skipped the cage and it needs cause I got it road ready and drove it instead but the one thing I did do was get four wheel disk (man I must be getting old) and that has saved the day.
I guess I'm sayin it'll be fun as he// any which way ya get it running that's for sure but get it the way you want it first cause you'll never wanna park it to do mods (at least for me)
Keep us updated
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Re: The Blue Goose
Postby 88Centurion » Wed Nov 14, 2012 9:43 pm
Im hoping to get it running and driving this winter dont know if thats gonna happen or not but this is my progress so far.
88Centurion
Re: The Blue Goose
Postby 88Centurion » Mon Jan 21, 2013 5:14 pm
Well been workin on the old girl off and on. Got new ball joints in the front rebuilt the calipers and put on new brake lines. Painted it all black and put it back together. Got the bed off and the fuel tank out and drained. Got started disassembling the engine tonight for new seals and such and found that my injection pump gear is cracked. Glad that I found that not sure what the out come of that could be but prob not good. Also found that the thermostat housing/altrenator bracket is cracked where the alt mounts. Gonna try to start doin some body work and getting it ready for paint this weekend maybe.
Will try to post some pics tomorrow
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Mon Jan 21, 2013 5:20 pm
Ive got a big list of stuff i need to get done to mine this spring. Look forward to seeing the pics.
Re: The Blue Goose
Postby 88Centurion » Tue Jan 22, 2013 6:22 pm
Well didn't get any time for pics today so maybe tomorrow if I have time. Got the engine torn down about as far as its gonna go. Still have to drop the oil pan and valve covers so not much left to do. Throw a fresh coat of paint on and put it all back together.
What all do you have to get done on yours dazed?
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Tue Jan 22, 2013 6:31 pm
That list is a mile long. :lol: Trying to find a good cab right now since mine is a rot box.
Re: The Blue Goose
Postby 88Centurion » Tue Jan 22, 2013 7:00 pm
Oh yeah that sounds like enough right there. I got really lucky on that . The drip rail has some rust in it but nowhere it is rusted through that I can tell so far.
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Wed Jan 23, 2013 6:40 pm
Something i just remembered, if you have to move the trans cross member back the cab will have to come off to drill the top holes.
Re: The Blue Goose
Postby 88Centurion » Wed Jan 23, 2013 6:55 pm
Yeah I'm hoping I don't have to but as far as I have it apart
now might as well pull it just for laughs.
88Centurion
Re: The Blue Goose
Postby 88Centurion » Wed Jan 23, 2013 7:28 pm
check out all the holes in the back of the cab
just about ready for a new coat of paint and some new seals
88Centurion
Re: The Blue Goose
Postby 88Centurion » Wed Jan 23, 2013 10:13 pm
My pile of parts
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Wed Jan 23, 2013 10:23 pm
What are the holes from?
Re: The Blue Goose
Postby 88Centurion » Mon Jan 28, 2013 8:21 pm
Looks like where stuff has been screwed to the back of the cab. This truck has been bought and sold several times so ain't no telling.
88Centurion
Re: The Blue Goose
Postby 88Centurion » Tue Jan 29, 2013 9:31 am
Got started painting the engine gonna paint the acessorys black and the vavle covers and timing cover same as color as the truck
88Centurion
Re: The Blue Goose
Postby 88Centurion » Tue Feb 05, 2013 5:42 pm
Ok guys I dropped the oil pan this afternoon to put on a new gasket before I put the motor in and this is what I found. It looks like what is left of a cage for a ball bearing but where could it have come from and is it some thing I should be worried about. I have had the engine running a couple times for just a few min at the time and it didn't seem to make any odd noises of any thing. Any ideas or thoughts are appreciated.
88Centurion
