At what point are piston lift pumps/stock lines inadequate?
Postby Bookshelf » Sat Dec 22, 2007 8:17 am
At what power level do piston lift pumps become inadequate? I'm talking about either the first gen style or the second gen ones you need to use a regulator with. Also, used in conjunction w/ a piston pump, when are the stock size lines a liability? I'm going to upgrade the turbo/injectors on one of my trucks this coming year, but don't want to get too greedy and have to end up doing a fuel system. Thanks-Nick
91.0 W250 Auto
90 Chevy V30
Bookshelf
Re: At what point are piston lift pumps/stock lines inadequa
Postby flashgordon » Sat Dec 22, 2007 10:30 am
Bookshelf wrote:At what power level do piston lift pumps become inadequate? I'm talking about either the first gen style or the second gen ones you need to use a regulator with. Also, used in conjunction w/ a piston pump, when are the stock size lines a liability? I'm going to upgrade the turbo/injectors on one of my trucks this coming year, but don't want to get too greedy and have to end up doing a fuel system. Thanks-Nick
I'm really not the right one, to answer that(as I'm still kinda stock) ,.......but here i go any ways :lol:
I thing once you have installed a piston lift pump, especially a 2nt gen with a regulator back to the tank, and your fuel system is starting to hold you back, that's when your weakest link or restriction is the filter.......Then better lines, bigger and better pump(s) .............................................
The 24V eng has a much bigger fuel filter system, and the new 6.7 is even bigger then that.
I thing that when your stock turbo can not be upgraded enough to keep it cool ..............It time to look, a lot closer to you fuel system
Flash
flashgordon
Postby bgilbert » Sun Dec 23, 2007 6:54 pm
I made 443rwhp with the low pressure piston pump 3936320 and stock fuel lines. My 91.5 has the same LP and 1/2"ID fuel pickup and supply and IMO that will be plenty for 400-500hp.
Bill Gilbert
Postby JAyers » Sun Dec 23, 2007 8:07 pm
Look at my sig. Piston pump with stock lines except for a remote mount 10micron filter with 3/8 lines from pump to filter, then to the inlet on the VE.
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby Bookshelf » Mon Dec 24, 2007 4:23 am
Thanks for the info guys. I have a set of POD's and a HTT 62/12 I was going to try out, it seems w/ the stock filter/lines and the low pressure piston lift pump I'll be good to go then. I'll probably at least temp a test guage in there and monitor full throttle fuel pressure when I get it together anyway.
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby cummins king » Wed Dec 26, 2007 4:04 pm
i have stock lines from tank then new stock lift pump with 1/2 to filter then 1/2 to ic pump and when i romp on it i can put the gague to 0 psi from 15 psi
93 4X4 auto
cummins king
Postby GLHS » Wed Dec 26, 2007 5:17 pm
The smallest tubing is the white plastic pickup inside the tank.
I think it's 7/32"?
GLHS
Postby Bookshelf » Wed Dec 26, 2007 6:56 pm
GLHS wrote:The smallest tubing is the white plastic pickup inside the tank.
I think it's 7/32"?
Man that's small, I thought the feed line was at least 5/16?
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby cummins king » Wed Dec 26, 2007 7:41 pm
wow thats small, i wonder if it will suck a half inch lines witch my new pick up will be
93 4X4 auto
cummins king
Postby flashgordon » Wed Dec 26, 2007 10:45 pm
cummins king wrote:wow thats small, i wonder if it will suck a half inch lines witch my new pick up will be
Yup! Right inside the 1/2 hose :lol:
flashgordon
Postby dpuckett » Sun Dec 30, 2007 8:22 pm
Considering that the injector holes are so much smaller than the lines, and considering that the VE runs lots lower pressure and volume than the P-pumps (P-pumps can top 1cc/ stroke), I wouldnt think the VE injector lines would be much of a liability to 5-600hp. Beyond that, I'm not sure. Heck, I'm not even sure about how close my thoughts are to actual reality.
ANother thing to consider is that if you go too big with the lines, you may run into issues with streetability, or dirving at less than full throttle.
Daniel
Postby ford69557ci » Sun Dec 30, 2007 8:26 pm
you are correct the larger lines screw with part throttle driveablitly but does make for a killer soundin idle
ford69557ci
Postby flashgordon » Mon Dec 31, 2007 6:53 am
ford69557ci wrote:you are correct the larger lines screw with part throttle driveablitly but does make for a killer soundin idle
so thats how i get my diesel, to lope like a big cam, gasser :lol: JK
Flash
flashgordon
