to P or not to P....that is the question
Re: to P or not to P....that is the question
Postby Tacoclaw » Mon Mar 18, 2013 5:12 pm
PToombs wrote:Thanks Taco! Nobodies called me "beefy" before! :mrgreen:
According to Hineman, you've earned it. He's quite the gossip. :puker: :pukel:
Postby PToombs » Mon Mar 18, 2013 5:18 pm
I'll have to put something in his mouth to keep him quiet! :mrgreen:
Postby ellis93 » Mon Mar 18, 2013 5:28 pm
oldestof11 wrote:Jeff Garmon has a 3rd Gen RCSB 2wd truck with a P-pump and 47RH.
Keeping the boost below 10psi, he got nearly 55mpg on a 100 mile trip. On the dyno, made 699.9xhp.
Hope that helps.
Holly crap :shock: ain't no way :o that is freakin crazy :lol:
Postby ellis93 » Mon Mar 18, 2013 5:37 pm
Jon....what all was done to it?
Postby turboram » Mon Mar 18, 2013 5:56 pm
Ive got 24 mpg going 65 mph in a 2wd p- pump...... my vote is keep the p. Its a lot of work to convert.... trust me done it,
turboram
Postby cmann250 » Mon Mar 18, 2013 6:02 pm
ellis93 wrote:Jon....what all was done to it?
Twins and IIRC head work and a cam. The 12v always tries to be efficient no matter what. The owner generally tries to decrease the efficiency ASAP :lol:
Postby Tacoclaw » Mon Mar 18, 2013 6:08 pm
Since that was was in some DP article I would assume it was an absolute best case scenario.
Probably involved a lot of downhill coasting and whatnot, probably down a mountain or something. If 55mpg was even possible I'm sure there's be a few more people closer than 1/2 way there in comparison.
Postby oldestof11 » Mon Mar 18, 2013 6:09 pm
From CompD. If you have an account, here is the thread, http://competitiondiesel.com/forums/sho ... hp?t=43915 If not, I will quote Jeff:
This is hard to believe I know, but I went to macon to the mall filled up
drove around 65 on the flats used no more than 2 or 3 psi going up hills
so it would fall back to 60 62 or so. got back to town filled up till it justabout ran out on the ground 105 miles on the speedo took 1.9 gallons
you have got to keep in mind 321 gears 22inch tires with .62% overdrive
it is basicly idling which burns about a gallon an hour which is exactly
what we used! It is cool to have the option to kill a street car or get
stupid fuel economy! Just depends on your mood for the day, I usually
dont get but 15 or so
Twins, 3.21 rear gearing, stock headbolts, 60mph he is under 1500rpms.
Postby Tacoclaw » Mon Mar 18, 2013 6:12 pm
Like I said.
Postby ellis93 » Mon Mar 18, 2013 6:18 pm
That's cool as an Eskimos butt, I'd be tickled schitless to get 25 or so 8) I guess I should just put it all together and see what happens.
Postby AHineman » Mon Mar 18, 2013 6:23 pm
WTH.... :shock: :roll:
I guess I'm going to have to start reading this part of the forum more often, seeing as my good name is getting drug through the mud and all. :yuck:
Levi's girlfriend must have left him again or at least be out of town....that's the only time he actually types his fantasies about me. Normally he just daydreams to himself. :?
Back on topic, I don't buy the 55mpg bs, but it sells magazines. Before twins and big injectors, just maxed stock stuff I got 24.93 mpg on a trip up to Wheeling WV and back. 8)
Also, I wouldn't change it over either.
Postby Tacoclaw » Mon Mar 18, 2013 6:32 pm
AHineman wrote:I guess I'm going to have to start reading this part of the forum more often, seeing as my good name is getting drug through the mud and all.
No pun intended? 8)
Postby AHineman » Mon Mar 18, 2013 6:34 pm
Let's try to keep the BS to your thread Levi. ;)
Postby oldestof11 » Mon Mar 18, 2013 6:42 pm
I would call BS too but they did have another person later confirm the same route, 52mpg. I guess the route is hilly from what the people who lived down there say.
Postby ellis93 » Mon Mar 18, 2013 6:46 pm
oldestof11 wrote:From CompD. If you have an account, here is the thread, http://competitiondiesel.com/forums/sho ... hp?t=43915 If not, I will quote Jeff:
Just checked out that tread.....pretty cool lookin truck to boot. It screams I was expensive :lol:
Do-able but expensive, I really don't see my old truck looking that good.....or getting that kind of mileage.......
