The Blue Goose
Re: The Blue Goose
Postby cmann250 » Tue Feb 05, 2013 5:50 pm
Do you have the diaphragm style vacuum pump? They've been known to send their bearing cage into the pan before.
Re: The Blue Goose
Postby Tacoclaw » Tue Feb 05, 2013 5:50 pm
Since that's a non-IC'd engine that's probably the cage from the Vacuum pump.
Re: The Blue Goose
Postby cmann250 » Tue Feb 05, 2013 5:52 pm
Tacoclaw wrote:Since that's a non-IC'd engine that's probably the cage from the Vacuum pump.
Tree'd ya :P
Re: The Blue Goose
Postby 88Centurion » Tue Feb 05, 2013 6:10 pm
It does and the guy I got it from said something about he had put a new one on it. So I should be ok then?
88Centurion
Re: The Blue Goose
Postby cmann250 » Tue Feb 05, 2013 6:15 pm
Especially if have the engine out, pop the cover off and check the gear teeth. Chances are, you're fine.
Re: The Blue Goose
Postby 88Centurion » Tue Feb 05, 2013 6:21 pm
The teeth look good there was actually a piece of it in there to still. Just wanted to be sure it wasn't anything major. Thanks guys
88Centurion
Re: The Blue Goose
Postby 88Centurion » Sat Feb 09, 2013 1:49 pm
I'm working on gettin my engine back in a pile today and was wondering if I skip one tooth and then retard the pump will it be close to stock timing still? Want to start close to stock so I can see how much each mod helps
88Centurion
Re: The Blue Goose
Postby 88Centurion » Thu Feb 21, 2013 7:47 pm
Test fitted the engine this week. After putting 2x4s under the front cab mounts engine and trans went in fairly easy.
Had to move the crossmember back and then had to cut out a notch in it to clear the fuel tank. So I welded a couple pieces of scrap to it to strengthen it back up. Having the front cab mounts on 2x4s also let me get the bolts out and back in. Drilled the holes with a right angle drill and a cut off drill bit. All in all wasn't to bad. Now just need to get some body work and paint and get it all back together.
88Centurion
Re: The Blue Goose
Postby 1STGENFARMBOY » Fri Feb 22, 2013 3:34 pm
:popcorn: :popcorn: :popcorn:
Re: The Blue Goose
Postby dazedandconfused » Fri Feb 22, 2013 3:41 pm
Glad to see it coming together.
Re: The Blue Goose
Postby SuperiorRam » Wed Jun 26, 2013 10:17 am
Must.... Have...... Update
92 Cummins: DD, basic mods, topper, 9'2" bossV
92 Cummins: 10' tall, Rockwells and r1's "Dirty Addiction",
83 RC/SB Cummins: engine set back 18", block 89w/h20 after cooler, fire ringed and worked head, studs, billet 64/68/14w/race cover, custom header, bigger sticks, 47rh, dana 60, four wheel disk, and big Mickey Thompsons w/ Weld drag lites. "The Mustard Bucket"
SuperiorRam
Re: The Blue Goose
Postby dazedandconfused » Wed Jun 26, 2013 1:24 pm
SuperiorRam wrote:Must.... Have...... Update
I was just thinking the same thing.
Re: The Blue Goose
Postby 88Centurion » Thu Dec 19, 2013 6:18 am
Well guys it's like this in the last year I have quit farming and started a 8 to 5 job and got married and had a kid. So needless to say the truck has been on the back burner but I am planning to get started back on it after the first of the year.
88Centurion
Re: The Blue Goose
Postby dazedandconfused » Thu Dec 19, 2013 6:48 am
I was wondering the other day what ever happened to this. Glad you still have it.
