'85 Crew Cab 12v swap
Postby toymaniac » Wed Jul 24, 2013 9:43 am
I picked up a a '85 crew cab dodge short bed one ton truck to use as a tow rig about 2 yrs ago. It has a '97 12v cummins in it. The previous owner got the engine in but didn't hook anything up. I had to sort through the mess of wires and figure out where everything goes. I do have a '90 wiring harness from a diesel truck to work with. And yes, I will be getting it painted once it's running.
Pics:
In my driveway.
The engine:
Here are the stock front springs. I ended up replacing them.
Here is the sad state of affairs inside. This is where most of the work will happen.
One more for good measure:
I ended up putting in a nv4500 transmission as the tranny that came with the truck was a non-overdrive TF727 from a '90 first gen cummins. The axles have 4.10 gears, so a non-overdrive tranny wouldn't work.
Leni
toymaniac
smoke screw?
Re: '85 Crew Cab 12v swap
Postby toymaniac » Wed Jul 24, 2013 9:47 am
Here are the motor mounts as they sat when I got the truck. The front is to the left in the picture:
This orientation causes the engine to be too far forward. The fan hits the bottom of the radiator bracket.
Here is how the motor mounts came out.
Lots of room for the fan now.
This is how I mounted the nv4500 to the '85 gas automatic tranny crossmember:
I also found a seal for the nv4500 output housing that fits the 29spline t-case adapter.
It's very thin but should keep the gear oil in the t-case out of the tranny.
As many have for sure noticed I have a NV4500 with an aluminum tailhousing. I could have swapped in a cast housing, but before doing that I chose to add a t-case support. I think it's stronger that the cast housing option:
Leni
toymaniac
smoke screw?
Postby toymaniac » Wed Jul 24, 2013 9:50 am
Put a ford super duty intercooler in. I ended up chopping up the grille to make it fit. I will end up with an intercooled cummins grille and radiator support if I can find one.
I also found some early ford F-350 Alcoa wheels to put on it:
It is running and driving right now. Finishing up a few thinks like a tachometer and a/c. I will take some new pictures soon.
Leni
toymaniac
smoke screw?
Postby rockbuggy4x4 » Wed Jul 24, 2013 1:33 pm
pics aren't showing up. :scratch:
Jimmy
--> '85 cab w/ '89 engine and trans stock with minor pump tweaks and a flatbed. **soon to get lots of goodies**
--> '95 jimmy not so stock
rockbuggy4x4
Postby dazedandconfused » Wed Jul 24, 2013 1:49 pm
No pics
Postby RCCUMMINS89 » Wed Jul 24, 2013 7:42 pm
I WANNA SEE PICS...............
Postby pettyblue440 » Sat Jul 19, 2014 6:53 pm
I see the pics, looks good
pettyblue440
smoke screw?
Postby dazedandconfused » Sat Jul 19, 2014 7:00 pm
Nice looking project.
Postby 69HemiGTX » Fri Oct 10, 2014 3:16 am
Old thread, I know, but you're one of the first ones to find a seal for the 29-spline adapter. Did you polish the outside of the adapter? I know they're far from smooth, so I'd think they'd chew up a seal pretty quick.
OIF and OEF veteran
98.5 24V CTD 4x4, AEM Brute Force intake, silencer ring MIA, Diamond Eye 4" stainless exhaust, more to come...
78 RC 4X4, 360, auto, original condition survivor, stuck in the back of a garage
78/84/93 Crew Cab Dually, Cummins, NV4500, 4x4 conversion, ugly as sin
69HemiGTX
Postby CumminsPower59 » Fri Oct 10, 2014 4:25 am
There is really no need for that seal, as the transfer case input seal is a double lip seal...even then, how do you seal up the splined area inside the coupler? No need ;)
Postby thrashingcows » Fri Oct 10, 2014 5:42 pm
69HemiGTX wrote:Old thread, I know, but you're one of the first ones to find a seal for the 29-spline adapter. Did you polish the outside of the adapter? I know they're far from smooth, so I'd think they'd chew up a seal pretty quick.
I was excited about that seal as well...then I read CumminsPower59 response.....Doooh! :?
CumminsPower59 wrote:There is really no need for that seal, as the transfer case input seal is a double lip seal...even then, how do you seal up the splined area inside the coupler? No need ;)
Never really thought of that. Guess you could try some RTV silcone in the threads to help minimize the oil infiltration?
thrashingcows
Users browsing this forum: No registered users and 127 guests
