99 ford explorer with a 92 12valve under the hood
Postby johndeeretech » Sun Nov 03, 2013 4:41 am
johndeeretech
Re: 99 ford explorer with a 92 12valve under the hood
Postby johndeeretech » Sun Nov 03, 2013 4:42 am
I will have the build list and pics up shortly
johndeeretech
Postby johndeeretech » Sun Nov 03, 2013 4:53 am
johndeeretech
Postby johndeeretech » Sun Nov 03, 2013 4:56 am
johndeeretech
Postby johndeeretech » Sun Nov 03, 2013 5:03 am
johndeeretech
Postby johndeeretech » Sun Nov 03, 2013 6:54 am
johndeeretech
Postby johndeeretech » Sun Nov 03, 2013 7:10 am
johndeeretech
Postby johndeeretech » Sun Nov 03, 2013 7:15 am
johndeeretech
Postby johndeeretech » Sun Nov 03, 2013 7:34 am
1999 Ford Explorer with a 1992 Gen 1 12v Cummins put in with right at 145,000 miles. 3334 miles on a PTC rebuilt A518 (2 wheel drive). AirDog 150 lift pump. M5 fuel pin 4,000gov spring . KDP mod.SKPP 6x.020 injectors beans diesel 64/71 whiplash turbo.Cooler tubes intake. Custom aluminum dash with digital gauges. Gauges include: water temp, oil pressure, speed, volts, boost, egt, transmission temp. Old school pioneer DVD player running through a Pioneer AVM9000R surround sound module, connected to a Memphis belle with 3 memphis 10 inch subs Boston Acoustic front components, memphis M-class rear door speakers.
johndeeretech
Postby CumminsPower59 » Sun Nov 03, 2013 8:56 am
That thing is pretty freaking cool!!! :thumright:
Postby ellis93 » Sun Nov 03, 2013 6:55 pm
Very nice :)
Postby johndeeretech » Mon Nov 04, 2013 9:22 pm
Thank you it is always under constrution and trying to get more power out of it and i will try to keep this thread updated with everything that i do to it
johndeeretech
Postby blowinsmoke8991 » Mon Dec 09, 2013 5:01 pm
That thing is sweet. How hard was the swap? What HP and ft/lbs are you making?
blowinsmoke8991
smoke screw?
Postby dazedandconfused » Mon Dec 09, 2013 6:01 pm
How did I miss this? This thing is awesome!
Postby brandonmgreer » Sun Mar 02, 2014 10:29 pm
who makes the digital gauge cluster, and where do I get one?
White/black 92 D250 manual conversion, Pump tweaking is about it right now...
95 CCLB 4X4 5 speed being but back together from a wreck
99 Kenworth W900 flat top, Tuned 500 Detroit, BW 75mm 1.32A/R, 5915 injectors, 13 speed, 3.55's
brandonmgreer
