coalroller1 wrote:also which driveshafts will work? i have both drive shafts off my donar but it was an auto and the getrags are quite a bit shorter has any body come up with a way to use a carrier shaft on a 4wd?
and the closest driveshaft shop is an hour away from me
BHD wrote: If you changed the mainshaft in the G360 and married the transfercase to it, the donor's driveshafts should work. I swapped my auto for a standard and reused both shafts with no issues.
CumminsPower59 wrote:BHD wrote: If you changed the mainshaft in the G360 and married the transfercase to it, the donor's driveshafts should work. I swapped my auto for a standard and reused both shafts with no issues.
Yup. The Getrag and 727 trucks share the same length of driveshafts...so I've heard.
