DYNAMIC TIMING!!!!
DYNAMIC TIMING!!!!
Postby JD91 » Thu Nov 21, 2013 2:55 pm
well i just ordered a timing spacer from M&H, and was wondering what yall fellers have to say about it. like what all it did you yalls setups and stuff like that. any info or heads up would be appreciated..
thanks
John
91 w250 RC, getrag, 4in turbo back diamond eye
93 D350 CC, getrag, 4in diamond eye, 60# springs,3200 gov,arp's,fass 150,fass sump, BD SUPER B 58MM, 5x14 sticks, M&H timing spacer, cut fuel pin,valair clutch, auto meter pyro & boost......she screams!!
91.5 d350 RC, getrag, cut fuel pin, no bed lol "the beater"
75 dodge club cab swb flat bed 4x4 "gasser" on 37's
JD91
Re: DYNAMIC TIMING!!!!
Postby JD91 » Fri Nov 22, 2013 7:23 am
So i take it nobody has installed this spacer then huh????
JD91
Postby RCCUMMINS89 » Fri Nov 22, 2013 8:06 am
I've run it.
At the time, best mod to date. Awesome product.
Setup at the time
stock injectors that we extrude honed
Denny T stg 1 pin
HE351Cw
1/4 timing bump, no ksb shims, plus spacer = a lot of timing
studs/o rings
pump mods
Dynoed 414rwhp. Alligator Dyno day...Oct. 2011
Postby 1992gen1_fan » Fri Nov 22, 2013 7:29 pm
I have one installed, like it prety good so far. I like it better than the 1/8" bump since base timing stays the same, so don't lose low end.
1992gen1_fan
Postby JD91 » Sun Nov 24, 2013 11:49 am
im installing my like as we speak. so RC you installed yours w/o the shims??
JD91
Postby RCCUMMINS89 » Sun Nov 24, 2013 12:37 pm
Yes.......I would first install yours as designed and per instructions. I did mine for an even faster, quicker advance. Which not all set ups work best for. Timing is a thing that one needs to play with and see how they like it the most.
Postby JD91 » Sun Nov 24, 2013 1:17 pm
Ok cool. I put mine in already it's just too wet to really get on it without ending up in the ditch. So ima wait for it to dry up some to test drive it.... It does sound nice tho when you romp on it!!
JD91
