coolhand_luke wrote:Can you post a link to your duramax build? I'm impressed by the size of your thread over there. It's obvious those guys are thirsty for some classic Cummins muscle
. Good choice by sticking with the VE. Go with a piston lift pump for reliability. Lots of good builds on here making different power in different ways. Can We get some pics over here?
Sure happy to accommodate!
Here's the D-Max build thread...Sorta large...
http://www.duramaxforum.com/forum/2011- ... hread.htmlI already added a piston lift pump, sump, 1/2" to 3/8" supply line and a filter/water separator to that fuel system
I'm building the truck an area at a time in what is becoming a total restoration with a ton of add-ons.
Right now I am almost done with the rear frame.
The bed is getting chemically stripped up in Cincannati. I rebuilt a Ford Sterling axle, added a locker, renewed and painted everything and bolted it in. I added a rear sway bar, bolted in new 6" skyjacker springs on all new hardware. I had a custom driveshaft built which is much stronger, rebuilt the brakes 12" X 3" dumped the RALB and ran all new fuel and brake lines. I dropped the tank, took the frame down to bare metal and repainted everything with a multi-process operation. I flipped the U-bolts and added custom lower shock mounts...You'll have to see all that here:
http://www.duramaxforum.com/forum/diese ... hread.htmlThe entire steering was rebuilt, new box, borgensen and so forth. King pin overhaul, pulled the front axle apart and rebuilt, all painted and pretty, armored diff cover, new brakes and so forth.
I gutted the interior, new headliner, repaired all the defective trim, dyed everything, repaired the rust (Minor) Lizard skin, new carpet, seal cover and so forth.
Added gages, a bunch.
On my desk beside me is a fuel pion, dynamic timing device, smoke control device, Banjo bolt delete kit. I have a 14cm exhaust housing and a 60mm wheel coming, and six injectors built by Gillett Diesel.
I will be adding a Power stroke intercooler, pulling the head for an O-ring, valve job, porting and polishing, and a 3 piece exhaust manifold. That's when I will modify the injection pump.
I am also doing body work as I go along. The truck is getting an inside/outside OD Green semi-gloss paint job, and I am recentering 5 HMMV wheels and will run the Armee 37" tires. I will also build a custom front and rear bumper that also replaces some of the fender and bed.
Anyway, I post up 50 pics a night and write 10 pages on Duramax forums and frankly, posting pics is just too difficult here, so I'd ask you to just go to the link there and participate
Best!
1991.5 RCLB 7" lift, 1" body lift, P-pump motor, cut delivery valves, 4K spring, ARP, 3.54, Sterling axle Lock Rite, 6" skyjacker 37" MTR's recentered HMMV wheels. Traction bar, boxed in frame, Hydro assist brakes, dual batteries, elec air pump, lift pump, extra filter, 3-piece manifold, Diamond 4", 4" driveshaft, X-over steering, isspro tach, EGT, boost, and more...
