coolhand_luke wrote:If your doing OD green, it would be sweet to do your bumpers and trim the military beige. The 1st gens look best in two tone
Tacoclaw wrote:Not following over there TBH, too many ads on forums like those. I'll stop by more often to see your suspension progress.
I haven't paid attention to what size tire you're running, but I can bind my u-joints with 35" tires before they even come close to the leaf springs. As long as your lower mounts are around that area you shouldn't have too much interference troubles unless your going real big.
Tacoclaw wrote:The joints at the end of my axle, the ones that allow your tires to turn. I put a crossover steering on and I could easily turn until my u-joints started hitting the yokes of the axle and stub before I had any tire contact issues.
You can get your yokes clearanced to allow around 45* of steering angle, but it seemed to be a somewhat specialized process that people send axles out to have done.
RCCUMMINS89 wrote:Hitting will depend on the offset of the wheels. I've had 15" wide tires that don't hit, and I've had 12" tires that do hit. The VAST majority of new wheels don't have the proper offset for our old style of axles.
flyin6 wrote:Any working knowledge about those?
Tacoclaw wrote:That's a good point, RC. I'm using H2 wheels with 1.5" spacers. I'm jealous of you having cut shafts though, it would be awesome to have a 45* steering angle.
RCCUMMINS89 wrote:flyin6 wrote:Any working knowledge about those?
Nope.... I've personally never even seen them. However, I've ran across a few threads in the past of guys using them.
