1972 Ford Crew Cab Conversion
Re: 1972 Ford Crew Cab Conversion
Postby dazedandconfused » Sat Sep 14, 2013 8:55 pm
You have to have 20 to pm I believe.
Postby grinnergetter » Tue Oct 01, 2013 6:53 pm
D&C...I think I found the needed parts locally for $30.00 but I really appreciate the offer.
Thanks again, Grin
grinnergetter
Postby grinnergetter » Tue Dec 10, 2013 8:17 pm
Finally back at this thing again. Removed the rear suspension preparing for a D80 swap. I'm going to set it up for 3" springs.
Waiting on U bolts and rear disc conversion. Got it cleaned up today and hope to paint it tomorrow. It also got new bearings etc. and rebuilt the posi.
I also found a high mount A/C bracket at my local JY. This one has different part numbers than what I found online.....but it will work and hopefully will allow the engine to move a bit more to the passenger side.
This setup requires using the water inlet that is on the donor.
grinnergetter
Postby grinnergetter » Sun Dec 15, 2013 4:51 pm
Moving along...I should have all the parts for the rear discs tomorrow so I gotta figure out these leaf hangers. I want to use 3" rear leafs so I have to swap to later hangers, which are taller sooooo.
Sheesh, I need to get a grip!! Nothing major but I thought it would be worse until I got the glove off.
grinnergetter
Postby ellis93 » Sun Dec 15, 2013 6:04 pm
Ouch! That sucked! :shock:
Postby dazedandconfused » Mon Dec 16, 2013 5:02 am
That is why I usually don't wear gloves. Was it a hot rivet or weld slag?
Postby grinnergetter » Mon Dec 16, 2013 9:35 pm
4" grinder...wrist length gloves.
grinnergetter
Postby PToombs » Tue Dec 17, 2013 6:24 pm
I thought it was a grinder burn. You gotta watch those 4" suckers, they twist real easy sometimes. I saw a guy do that with a real heavy duty 9" grinder a long time ago, I thought he took out all his veins, it was nasty. When he came back to work the grinder had a big red circle with a line thru it and his name inside the circle. He didn't think it was funny, but we did. :mrgreen:
Postby grinnergetter » Tue Dec 17, 2013 9:13 pm
Haha, you would think they would come out with a grinder that had a better place to grab hold.
Mocked up the discs today and got everything painted. Of course now I've read a few posts here and there saying the e brake calipers suck. Gotta love it.
Also picked up another block. This will allow me to continue arguing with the engine and I can hang it over the side of the frame. I don't have enough space to put a hoist in front of my truck in my blood barn.
It also allows me do build something....funner...while driving this truck. :D
grinnergetter
Postby PToombs » Wed Dec 18, 2013 6:43 pm
You'd make better progress if you quit arguing with the engine and jam the SOB in the truck. All arguing does is upset you and lets the engine feel morally superior. :lol:
Postby grinnergetter » Tue Dec 31, 2013 8:42 pm
Welp, before I get to argue with the engine I have to get her back on 4 wheels. I'm using 3" leafs so that required hangers from a 78-79 F250 and a little cycling the leaf and some welding etc.
D80 is almost temporarily in...just have to get the other 2 hangers done. Lotsa thinking and a little doing.
grinnergetter
Postby grinnergetter » Wed Jan 01, 2014 8:05 pm
Made good use of a day off :
grinnergetter
Postby grinnergetter » Sun Jan 12, 2014 6:43 pm
Got the truck flipped around in the barn and picked up a spare oil pan so I could "argue" with the engine some more.
The high mount A/C bracket netted me about an 1-1 1/4 passenger side and I can get more if I mod the lower water pump tube.
TC/Frame.....I can add back a bunch to the frame.
Ordered new body mount kit so I can nail down cab position. Also want to try a set of 2nd gen engine mounts...just need to find them.
Wouldn't you think someone would be smart enough to put the factory washers in with the poly bushings and sell them as a kit? That was an aggravating $300.00 / 2 day search...blaa, blaa
,blaa
grinnergetter
Postby Billy Bones » Mon Jan 13, 2014 10:50 am
Off topic but where did you get your welding clamp and how do you like it? Great job on the build!
Billy Bones
Postby grinnergetter » Mon Jan 13, 2014 7:56 pm
Seems like they came off the Snap On truck but all those body repair web sites should carry them. I like them for clamping large pieces of metal to control warpage while welding....especially the thinner stuff.
grinnergetter
